Role center is not loading
Hello,
when i am trying to load role center it as not loading. it is working fine for only CEO user profile but for other user it is not loading. I had seen log file it is giving below error
Windows SharePoint Services General 8e1n High Failed to create a user control from virtual path ‘/_controltemplates/AxSearchArea.ascx’: c:\Program Files\Common Files\Microsoft Shared\Web Server Extensions\12\TEMPLATE\CONTROLTEMPLATES\AxSearchArea.ascx(60): error CS0144: Cannot create an instance of the abstract class or interface ‘Microsoft.SharePoint.WebControls.SearchArea’
processing cube was also done but problem is still there. Any solution please help.
hardik
You can redeploy your website from Admin>setup>EP.
Tried that but same issue. Problem not solved.
