I have set up my Robo Help But i dont know how to set up Gate Document properly.AnyHow i managed it by reading help. But after compliling Its giving following error. File not found: addin_a.brs File not found: addin_a.ali AssistEdit_12pix.gif is not present in the Shared folder and could not be copied. DrillDown_12pix.gif is not present in the Shared folder and could not be copied. DropDown_12pix.gif is not present in the Shared folder and could not be copied. Lookup_12pix.gif is not present in the Shared folder and could not be copied. The master stylesheet was copied from the \Shared folder GATE failed to find the following in Object.txt: T_12345678 R_12345678 B_12345678 T_12345678_1 T_12345678_2 Anyhelp would really be appreciated.
