How rework on rejected manufactured material is maped in AX
It depends what you want, you can rework against the original, you could have raised a non-conformance, or it failed quality and you capture material and labour in new journals, it could be it is a new order with a BOM consuming the rework. I believe process has some rework elements as well.
