Reversing shipments
hello,
I have a question, hope it is not stupid :wink:
I have tested the function “Reverse shipment” and found the following: the function creates a negative line and so the quantity on stock is corrected.
That’s fine, but what with the item entry with type “purchase” that the sales line has been applied to? the remaining quantity is not corrected and the
application between the positive entry and my (reversed!) entry is still existing… :-((
in my opinion that’s not correct, can somebody please explain me this?
thank you
angelina
Which version of Navision are you using? Is it a standard version? As far as I know, it is not possible to reverse an applied entry - which is stupid, I know, since a shipping entry is quite unlikely to be unapplied, but that’s it. [:(]
hello,
parli italiano? sono anch’io italiana, in caso… :wink:
I’m using the 4.20 IT Version, and the shipping was possible… there was no error message or kind like that…
only the result was a catastrophe…
bullshit, why do they insert functionality that doesn’t work in the program???
greets :slight_smile:
angelina
Sì, ma nel forum italiano. [:)]
Smells of bad customization. [:P]
