Reversing production order AX2012
Dear all:
First , I would like to thank all the dynamics user family.
I want to ask if there is a way in AX2012 to reverse or cancel the effect of “Ended” production order , if there is no way please provide me with suggestions to cancel the effect of the production order (Physical effect and financial effect).
Many thanks in advance.
Regards
Once Ended it is financially removed from WIP and all known costs are flushed, you cannot reverse it.
Use an inventory adjustment journal to book remove the output, depending upon your setup of item tracking use marking.
I doubt you want to put teh components back but you do the same - if you need to put the components back you need to ask questions about the business process. [:D]
