reverse string example without using strrev function
can anybody give example program on reverse string without using strrev function through x++?
moulali.
str revString(str strVar)
int i;
str temp;
str retVar;
strLen=strVar.length()
for(i=strLen;i>=1;i++){
temp =SubStr(strVar,i,1);
retVar +=temp;
return retvar ;
plz check whthr it is working or not .
tc.
hi,
try this it will work…
static void revString(args _args)
int i = 1;
str temp;
str retVar;
str strvar = “chaitu”;
int l = 0;
l = strlen(strvar);
for(i=l;i>=1;i–)
retVar +=temp;
info(retvar);
