I’m pretty new to NAV and am using a very old version (Ver 5.0). My question is:
We have a user who has added several lines of text to a Return Order, this has been processed and a Sales Credit memo produced. However I now cannot find this text that was added to the Return Order. I’m searching the back-end tables using SQL.
Any suggestions as to where I can find this text would be appreciated.
Not quite sure I understand the question. You have a return order, with text lines (and regular lines I assume?). Now you have posted it and produced a posted sales credit memo. But the text lines are gone when you use SQL to search for them?
Question 1: Exactly how did you use SQL to search for them? Which table did you search? When NAV posts a RO, then just as when posting a SO, then if complete all it’s lines in table 37 (sales line table) are removed.
Question 2: Are the “regular lines” still there?
Question 3: Why did you use SQL to search for it? Why not just running the table in the object/table designer?
PS: I’ve moved your question from the generic Dynamics 365 group/forum into the Business Central/NAV user group.
Thanks for your response, to answer your questions.
I looked in Sales Cr_Memo Line (I thought this was logical)
Yes the regular (transaction) lines are still there
I used SQL because I’m very new to NAV, but I do understand SQL.
So your statement in 1. regarding a posted SO suggests that only the Transaction lines are retained when a SO or RO are posted (these appear to be line type 2 in the Sales Cr_Memo Line table). However I do have other credit memo lines, created at the same time, that have also retained line types ‘Zero’ & 1, that look like text lines. I just confused why this appears to have not happened for the credit memo in question.
