When i want to return invoiced sales order it is accept to return more times and applied to entry no is blank
how i know which document sales invoice returned
and how to block invoiced sales order from returned more time
if possible help me
why applies to document no blank
and how to prevent or block invoiced sales order from returned more time
Applied to document no is blank when i make return order
and if no applies to document no it is accept
how this happen and how to block return order without it has applies to document no blank
How i know applies to doc no and why it is blank
Are this technical problem or what
please help me in that
i have navision 2009 r2
have two fields applies to doc no doc type
and i return order using copy document
and how navision accept that and document rerurned not include posted invoice returned
please help me
It is clear from your screenshot that Document is not applied during Sales Credit Memo .
If it is not applied then how you can get the same ??
Thank you for reply
More entries i see applied to doc no and document type without applied credit memo
and how to apply using credit memo
can you tell me how to apply documents
You need to apply from customer ledger entries.
Functions–Apply Entries.
Select invoice and then click on Apply entries and select credit memo .
Thank you for reply
this is before i make return order to specified invoice or after i make return order
Before you post return order apply entry to specific item line with correct document no.
ok thank you for reply
but some times some people forget and return unapplied entries for more times and it accept
how to prevent unapplied entries from display or show when i make return order by credit memo copy document
if you have any ways possible for this
