Return Shipment Report bug
I am not sure where I can report a bug, so I hope it gets to the right place. Navision Attain 3.10B. Report 10127 - Return Shipment. “Return Shipment Line” OnAfterGetRecord trigger, the following code: ReturnLine.SETRANGE(“Document No.”,“Return Order No.”); ReturnLine.SETRANGE(“Line No.”,“Return Order Line No.”); should be replaced by: ReturnLine.SETRANGE(“Return Order No.”,“Return Order No.”); ReturnLine.SETRANGE(“Return Order Line No.”,“Return Order Line No.”); If the return order is posted already, then we need to find all the return shipment lines for the current return order number and line. It will be clear if you read the code. Thank you, Carmen Stanciulescu CSB Systems
