Hi team,
I created a return order and I chose’’ scrap’’ as disposition code, at validation of picking slip error message appears saying’’ Production number is not specified’’? is there a specific setting has to do for disposition code’’ scrap’’ ?
thank’s in advance
I would say this is non-standard and there is a modification impact here. Can you debug it?
firstly, thank you for the reply
it’s full standard !! what it seems you nonstandard ?
You do not need to define a production order to scrap a sales return. It could have bene purchased, it is an error that would not be called as a standard process.
Can you post a screen shot of the error please?
hi
below a screen shot of the message error
Have you specified a quarantine number sequence in the stock parameters?
The quarantine order usually triggers a quality order also, I think you should close the quality order as rejected or if not, close the quarantine order before picking slip the return order.
