hi everyone,
can you please help me to find out how can i compare the first 3 items lines in a Invoice, return the ‘Unit Of Measure Code’ and present the first line in order of the “Line No.”.
i already knew that the 3 lines are like this.
i just need an example Code.
Fields : Line No. P.Key Type Unit of Measure Code
10000 Item STÜCK
20000 Item STUNDE
30000 Item STÜCK
RECORD : SalesInvLine T113
it will be very helpfull.
thank you in advance for making time to read this.
Best regards,
Ayoub
What is condition to get ‘Unit of measure code’ after compare lines.
Hi Ayoub,
If you Know the Concepts of Arrays Then i would Provide Solution.
is there no solution without using Arrays?
i unfortunately don’t know the concepts
ok then
i would Simplify it your Concept then
Do you Know Cases i.e Conditional Statements in nav if No Click Here
SalesInvLineL.RESET;
SalesInvLineL.SETRANGE(SalesInvLineL.“Document No.”, pDocumentNo);
IF SalesInvoiceLineG.FINDSET THEN BEGIN
REPEAT
CASE SalesInvoiceLineG.“Unit of Measure Code” OF
Code1L :
BEGIN
Count1L := Count1L + 1;
End;
Code2L :
BEGIN
Count2L := Count2L + 1;
End;
UNTIL SalesInvoiceLineG.NEXT =0;
END;
//highcount int variable
IF Count1L >= Count2L then
OutputCode := Code1L
Else
OutputCode := Code2L;
Did you find solution to the problem?
