retrieve value
Hello,
I have table with two fileds (field1 and field2). Now, when I fill field1 in then in field2 should write value from field2 permanently. Even if i change value in field1, field2 should not be changed.
For example:
  1. field1 = 20
    field2 = 20 (download value from field1 automatic)
  2. field1 = 30
    field2 = still 20
  3. field1 = 2
    field2 still 20
etc.
How implement this in Axapta.
Best regards.
When the field1 is modified, check whether a value exists in field2, if not push that into field2…
some thing like this,
if(!table.field2)
table.field2 = table.field1; (when the field1 is modified)
thanks for answer
my next question is where do I check this?
How set permissions to the field2 only to reading?
Make the field2 un-editable. Trigger the code in the modified event of field1 in the form data soruce or override the modifiedField method on the table depending on the requirement.
thanks
thanks
