How to retrieve the last 7 records in a table using X++.
Thanks & Regards,
Chutti
Thanks & Regards,
Chutti
You can use select firstOnly10 … order by … desc to return last ten records. Then use a counter to fetch seven records only.
For example:
while select firstOnly10 t
order by Field1 desc
i++;
if (i == 7) break;
