In AX2009 for standard reports, we can filter the report via Select button and passing the required values.
I want to display those values on my report. How do I retrieve them ?
use ssrs report and give the parameter and filter criteria in that
We dont have SSRS installed, so i am left with standard report
then you can use dialog at the time of report generation …
got it
this.queryRun().query().dataSourceTable(tableNum()).findRange(fieldNum(, <Your_Division_FieldName>)).value()
You can get the query by simply calling element.query() in your report. By the way, look at printQueryRanges() method in LedgerBalanceSheetDimPrint report.
i tried element.query().toString()
it returns "Query Query Object " how do i get that value on a display method ?
Why don’t you simple look to the method I mentioned? It’s all already there.
void printQueryRanges(
Query _query,
boolean _showEmpty = true
TmpSysQuery tmpSysQuery;
int dataSourceCnt;
int i;
int j;
int rangeCnt;
QueryBuildDataSource queryBuildDataSource;
QueryBuildRange queryBuildRange;
dataSourceCnt = _query.dataSourceCount();
for(i = 1; i <= dataSourceCnt; i++)
queryBuildDataSource = _query.dataSourceNo(i);
rangeCnt = queryBuildDataSource.rangeCount();
for(j=1; j <= rangeCnt; j++)
queryBuildRange = queryBuildDataSource.range(j);
tmpSysQuery.clear();
tmpSysQuery.Tablelabel = TmpSysTableField::tableLabel(queryBuildDataSource.table());
tmpSysQuery.FieldLabel = TmpSysTableField::fieldLabel(queryBuildDataSource.table(),queryBuildRange.field());
tmpSysQuery.RangeValue = queryBuildRange.value();
if (_showEmpty || tmpSysQuery.RangeValue != '')
element.send(tmpSysQuery);
