Retail- Add one more field in interface
HI All,
The below is a interface code created by Ax for Table fields. (Table name: InventJounalTrans , Counting journal)
I want to add one more field to it. But not sure where to add. This is created as metat data by Ax.
Can you please suggest something.
using System;
using System.Runtime.InteropServices;
using System.Xml.Linq;
namespace Microsoft.Dynamics.Retail.Pos.Contracts.Services
[Guid(“9501CD08-DBEF-4644-B6FB-9A40C73C5072”)]
public interface ISCJournalTransactionV1
string ConfigId { get; set; }
decimal Counted { get; set; }
string Guid { get; set; }
string InventBatchId { get; set; }
string InventColorId { get; set; }
string InventDimId { get; set; }
string InventLocationId { get; set; }
string InventSerialId { get; set; }
string InventSiteId { get; set; }
string InventSizeId { get; set; }
string InventStyleId { get; set; }
string ItemId { get; set; }
string ItemName { get; set; }
string Message { get; set; }
string RecId { get; set; }
bool UpdatedInAx { get; set; }
string WmsLocationId { get; set; }
string WmsPalletId { get; set; }
void Parse(XElement journalTransaction);
string ToXml();
