hi all,
I have a combo box and i want to write a select command and fill data to combo box
please guidance me
thanks
hi all,
please guidance me
thanks
Please elaborate your requirement
Kindly give the detailed info … Here is one example with what i have understood on ur query.
Select forupdate yourtable where ( give the req condition);
yourtable.combofield = yourtableenumtyp::selection;
yourtable.update();
Thats al…
Thanks and regrads,
Kevin
Why do you specifically want it to be a combo box and not a standard lookup?
SysTableLookup class could display something based on a query
Global::pickList() is an example of showing a list of elements in a different way, which can give you another perspective.
THANKS ALL,
i want to click button and filter combobox automatically
for example with click just select number assement_id==2
THANKS ALL,
Then it’s not really a combo box in AX terms. just a normal lookup
and that’s why you should look for example of using SysTableLookup class
hi kashpeuk
thanks for guidance
i have two sys table lookup i want when a lookup change text other lookup filter whit selected lookup value
like this :
Hello JM,
In the second lookup method, pass the value of the first control value in the queryBuildRange.So it filters the records based on the first control.
let say, in the 2nd control of the lookup method
qbr.value('Pass the first control<Assement_id>).
