Restoring Error
Hello guys,
What is the causing of this error message:
You cannot delete or change the type of the Components on Sales Order field(in the Customer table) before the value in the field is reduced to 0 (zero) or ‘’ (blank) in all records. This message occurred because a nonzero value was found for the record No,=’ALOTOU’ in Company Development.
I was trying to restore my data without any transactions into new database.
ZB
Hi
It sounds like the table structure of the customer table in the database you backed up from and the one you are restoring to are different. There maybe a field in the data you are restoring that does not exist in the database you are restoring to.
You will need to make sure that the tables are the same in both databases before you can restore.
Hope this helps.
