Restoring backup of Ax2009-SP1/SQL2008-SP1 from AD1 of Win2008 ent R2 to AD2 of Win2008 ent R2
Dear All
I am trying to Restore the backup of AX2009 SP1 , SQL2008 sp1 , Active Directory -1(AD1) in WIN2008 ENT R2 ( live environment) TO
AX2009 SP1(complete appln files) , SQL2008 sp1 (full dbbackup.bak) , Active Directory -2 (AD2) in WIN2008 ENT R2 ( Testing environment)
installation on different domain was correct, AOS account of different domain has admin access rights in AD2 and sqlserver , in user mapping i select right db, with access db_datareader\writer\ddladmin and in stored proces full access to create serversession\ CreateUsersessions
when i restore this backup in same domain (i,e AD1) on member servers (for training system) its work fine.
But after restoring this backup in different domain (i,e AD2)
when i try to start the service for first time i get message as your AOS NUMBER LICENSE IS EXCEEDED in Event Viewer. i repeat this after restarting the server, but same error msg.
Note:- AD2, AX2009,SQLSERVER 2008 ALL ARE ON ONE MACHINE \ SAME HARDWARE.
any help is appreiciated.
thanks in advance
hashmath
thank god I succeed
