I am trying to restore a migrated NAV5.0 database to NAV2009 on SQL.
I create the database on SQL and I have run migrate on the NAV5.0 database. Then I have made a backup of the NAV5.0 database and try to restore this backup into NAV2009 in the SQL database.
But the restore stops in a step called “Processing Objects”. I cannot recall this step in the restore process from earlier versions.
I have tried the following with no luck:
expanded all database files well beyond the required size
restored only objects
Has any of you had the same problem?
Does anybody know what “Processing Objects” means?
Any error message raised? Just stopped?? I guess “Processing Objects” is related to the compilation of the objects for the RTC. If you disable the option “Enable for MS Dynamics NAV Server” (in NAV - File - Database - Alter - Page “Options”), does it work then?
there was no error message. But it seems now that my patience ran out before it finished.
In my last atempt I had restarted the restore before going out to dinner. Now when I come back it has actually finished the restore sucessfully. There was however a message saying “The compiler found errors in 1540 objects during an import or restore”.
So it seems everything was OK. I was just too quick killing the process as I did not know about the RTC object compling during restore.
