Restore native database on sql database
I have a problem with restoring a native database backup in a sql Database. When I try to make this, the sql database have blank Tables. This Tables don’t have Records. The Database is a 20 GB Navision 4.0 with 50 Companies. I will Restore 4 new Companies on the sql Database. There are many tables that are not datapercompany. Hopefully, Somebody can help me Thanks
Did you mark the “data common to all companies” boolean when creating the backup? This triggers the backup of shared tables.
Also when you import, it must be a new database (no companies might have been imported before) otherwise those tables (DataPerCompany= No) would not import any data.
Hi Solich. Did you manage to resolve this? Can you create another backup and try again?
