Restart Ax2012 Client while creating Purchase order
I import vendor data through Excel template in Ax2012.i select vendor while creating Purchase order the client application is closed.
Please give me the solutions as early as possible.I need very urgent.
Have you checked the eventviewer?
What if you use payment journal or other transaction? Check that also
Pranav…
Hi pranav,
I checked payment Journal and transactions in that their is no problem and in the event viewer i get this error
Application: Ax32.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.InvalidOperationException
Stack:
at System.Windows.Threading.Dispatcher.VerifyAccess()
at System.Windows.Media.CompositionTarget.VerifyAPIReadWrite()
at System.Windows.Media.CompositionTarget.set_RootVisual(System.Windows.Media.Visual)
at System.Windows.Interop.HwndTarget.set_RootVisual(System.Windows.Media.Visual)
at System.Windows.Interop.HwndSource.set_RootVisualInternal(System.Windows.Media.Visual)
at System.Windows.Interop.HwndSource.Dispose(Boolean)
at System.Windows.Forms.Integration.ElementHost.Dispose(Boolean)
at System.ComponentModel.Component.Dispose()
at Microsoft.Dynamics.AX.Editor.UI.EditorControlContainer.Dispose(Boolean)
at Microsoft.Dynamics.Kernel.Client.ManagedControlHost.EditorControlContainer.ReleaseControl()
at Microsoft.Dynamics.Kernel.Client.ManagedControlHost.EditorControlContainer.Dispose(Boolean)
at Microsoft.Dynamics.Kernel.Client.ManagedControlHost.EditorControlContainer.Finalize()
