Issue is customer has a simple two step route, each with a resource group which each have two resources within them.
10 Route Step 1
20 Route Step 2
ResGrp1- Resources-Line A, Line B
ResGrp2- Resources-Line A, Line B
The customer wants a specific sequence to occur once MPS has chosen resource based on capacity. Meaning, if Line within Op10 is chosen then Line A of Op 20 must be chosen, so forth for B as well.
I see sequencing and sequence groups in R2 and since this is a process industry, great, but not on R2 at this client.
Is there a chance to use capabilities here? Is there a checkbox or parm we are missing? Best practice suggestions needed here please.
Thanks in advance
I do not believe this is possible, you are sequencing on the operation previous irrelevant to the item on it. Are Line A in ResGrp1 and Line A in ResGroup1 physically different? There is new functionality around scheduling but I have not read anything that would allow this configuration based upon planning scheduling a line in operation 1.
Yes sir, I believe I have exhausted all my possibilities and have not found a vanilla solution. Even with R2 and sequencing it will not respond in this matter. I tried to working around using capabilities, I tried approving routes and not activating either of them (A to A, B to B), but obviously MPS doe not like that. Thinking it will require some coding work. I at least wanted to see if anyone had tried or come across this before admitting defeat.
Chris
