Hello.
I need on runtime to know the exact values (in mm) of right edge, left edger, height of the whole report.
How can I resolve that values?
Hello.
First, I’m curious if the “right edge” issue you are trying to resolve might be another mistake you are not noticing. If, when you go to “print to screen”, you choose the wrong printer, it will often give that “right edge” error.
Say for example you have “HP Printer 123” and “Microsoft XPS Printer”, and you choose print to screen…well for whatever reason what I have experienced many times is if I switch between the two, one give me that “edge” error. Or if you use something like “HP Universal Print Driver”, it might print to the edge.
Try verifying your driver and selected printer.
