Reset "Qty. to Handle" to 0 after registering a pick
Hello,
On the Warehouse Pick page, I am trying to reset the “Qty. to Handle” field to 0 after registering part of the pick. Right now, if there is a pick for a quantity of 100 and the user registers a pick for only 40, the “Qty. to Handle” field will populate to the remainder of 60. How can this be reset to 0 after registering?
Hi Jordan,
To solve your issue.
  1. Create a new field in Warehouse Setup table called “Autofill Qty to Handle on Reg. pick”
  2. Open Codeunit 7307 Whse.-Activity Register
  3. Search for " WhseActivLine.VALIDATE(“Qty. to Handle”,QtyDiff);" And replace it with
WhseSetup.Get;
if WhseSetup.“Autofill Qty to Handle on Reg. pick” then
else
WhseActivLine.VALIDATE(“Qty. to Handle”,0);
Hello,
I added that field to the Warehouse Setup table and also the page. I checked the box. Then I added that code where you said to:
IF WhseActivLine.“Qty. Outstanding (Base)” > QtyBaseDiff THEN // round off error- qty same, not base qty
WhseActivLine.“Qty. Outstanding (Base)” := QtyBaseDiff;
WhseSetup.GET;
IF WhseSetup.“Autofill Qty. to Handle” THEN
ELSE
IF WhseActivLine.“Qty. to Handle (Base)” > QtyBaseDiff THEN // round off error- qty same, not base qty
WhseActivLine.“Qty. to Handle (Base)” := QtyBaseDiff;
Unfortunately, the “Qty. to Handle” field still does not reset to 0.
