Reservaion on Released Prod. Order Components
We are trying to run the consumption for the Production BOM and I am getitng an error that “The reserve item is not on inventory”. Even if we don’t have enough output or on hand qty, we still want to consume it. It can go negative. It works fine if I only have one line in the released production order. But if I have the whole production tree then it auto reserves the item. Can someone help me please. I just don’t want to reserve an item automatically on the production order.
It is default in NAV that you MUST have the components you post as consumption, if you want the ability to drive stock negative you need to modify the system to achieve this. This topic has been discussed in many threads in this forum, please use the search.
