Adam, sorry for the late reply.
I spent almost 4 days to do Various testings and honestly the Manuals Microsoft provides are too high for an end user perspective, i mean’t it should be in lay men terms. Do you have any tailor made Documentation which you might have given to your clients?
SKU Card (Ordering Policy: Fixed Reordering Qty) Replenishment = purchase, only Safety stock was setup.
This is what we found out in Testing:
- Qty in Transit: It works given this scenario,
Receipt date : 26/03/10
and then we need to enter the Requisition date as below:
Order Date: 26/03/10
End Date: 26/03/10
or if there is a Demand (sales order) which falls in between the receipt date and end date then Qty in Transit tries to offset the Qty for Sales lines, so that it does not create a new purchase in Requisition lines.
Expected Receipt Date ( lines): This is not taken care the way we expected.
We have set up “Safety Lead times” in SKU card, when we run the Requisition work sheet, it gives a “due date” this is equal to Order date which we enter before we run the MRP sheet or it gives the date picked from Sales Order demand (shipment date). We assume the logic is that it needs to be purchased on the Day of the Shipment for Sales Orders so that stocks are available for .
When the Purchase lines in planning work sheet are converted to Purchase Orders, the Expected receipt date is not calculated by Safety lead time + inbound warehouse handling time, but instead it has picked up from the Due date field from the Requisition lines. So, this is not logical!! we wanted the system to give us the Expected Receipt date based on our lead times so that we can plan for the incoming shipments.
Is there any way to make this work?
But when we create a new , it picks up the lead times from the SKU and includes the Inbound warehouse handling times and gives us the correct "Expected receipt date" which we think is correct
So, we were not sure why it doesn’t work with Planning work sheet.
The rest all Scenario’s worked fine as what we expected based on the setup’s we did for SKU.
Appreciate if you can share your ideas and to suggest if there is another way of setting up SKU to achieve the above missing functionalities.
Jack.
