Hi While refreshing Planning worksheet only the items having Requisition Method code “6” is working. The Requisition Method code “6” is a combination of following options. a)Manufacturing policy - Make to Order b)Calculate Below Reorder point - Yes c)Reordering Policy - Blank d)Calc. with Inventory - Yes Our problem is - Items having Requisition Method code other than “6” is not functioning while refreshing Planing Worksheet. Ravi
Hi Ravi, Which version of navision are testing this case on. Can you be a bit more specific about the other items and the Requisition method codes used for them. In the mean time check the Starting date, Ending date in the planning line and other order modifiers in the item card. Regards, Srinivas Shetty
