Requisition line convert to purchase line
hi,
I am facing a problem when i create a requsition from sale order, and calculate a plan(same item with same vendor ) then two or more line are created then click carryout action message then purchase order created with two item(Item is same with vendor) but client requirement is if item and vendor is same then create only one line for same vendor. i write a code of 333 codeunit (insert purchase header function) but same item cannot be acumalte with Quantity. where exact location of write a code.(Please write a littile bit code).
Sunil Mishra
You need to write code in CU 333 Function InsertPurchorderline
LineCount := LineCount + 1;
IF NOT PlanningResiliency THEN
Window.UPDATE(4,LineCount);
TESTFIELD(“Currency Code”,PurchOrderHeader.“Currency Code”);
//Customized Code
recPurLine.RESET;
recPurLine.SETRANGE(recPurLine.“Document Type”,PurchOrderHeader.“Document Type”);
recPurLine.SETRANGE(recPurLine.“Document No.”,PurchOrderHeader.“No.”);
recPurLine.SETRANGE(recPurLine.“No.”,ReqLine2.“No.”);
recPurLine.SETRANGE(recPurLine.“Variant Code”,ReqLine2.“Variant Code”);
IF recPurLine.FINDFIRST THEN BEGIN
recPurLine.Quantity:=recPurLine.Quantity+ReqLine2.Quantity;
recPurLine.VALIDATE(recPurLine.Quantity,recPurLine.Quantity);
recPurLine.MODIFY;
END //Customized code
ELSE
Change as per your requirement.
suppose that Requsition line Created after calculate Plan
Item A 5(qty) V1(vendor)
A 10(Qty) V1
B 4(Qty) V1
then create a purchase order (after carry out action message)
A 15 V1
A 10 V1
B 4 V1
But Client Want
A 15 V1(Accumalte the item with Qty ,Item display only one time)
B 4 V1
Have you tried above code ???
I tried then reply to you with above example.
thanks
Problem solved problem is me end.
Sunil
Good
