I am facing the problem while installing ax report extentions component.
Error: " You must install SQL server 2005 reporting services service pack 2 before installing the reporting services "
Regards
Jayesh
Regards
Jayesh
Hai Jayesh ,
See the following link it may help u
When installing the reporting extensions, you may receive an error message that states that you must install SQL Server 2005 Service Pack 2. If you have installed SQL Server 2005 Service Pack 2 and receive this error message, complete the following steps.
Open the registry and find the HKLM\SOFTWARE\Microsoft\Microsoft SQL Server key.
Right-click the HKLM\SOFTWARE\Microsoft\Microsoft SQL Server key and choose New > Key.
Name the key Reporting Services.
Right-click the Reporting Services key and choose New > String Value.
Name the string value Version. The Version string value will have a type of REG_SZ.
Double-click the Version string value and enter 9.00.3042.00 as the value data. Click OK.
I’m afraid that he isn’t waiting for your answer five years later…
