Request report show only output and negative adjustment in inventory proplem
Hi guys when i make reverse to output for production order it must add negative adjustment.
so that I make report for contain to one data item .
this data item item ledger entry .
after reverse out put it will come negative adjustment
What i need to show only entry type output and negative adjustment
ex :
if i make output 50 then make
negative adjust -50
how i show only output and negative adjustment from item ledger entry table
How i do that
thanks
I using in data item table view properties of report to item ledger entry table the following statement : SORTING(Entry No.) ORDER(Ascending) WHERE(Entry Type=FILTER(Negative Adjmt.),Entry Type=FILTER(Output)) what i do it show only output entry type i need to show only output and negativeadjustment but all entries type remaing as purchase sales consumption no need / please if any one know tell me . thanks
Did you try WHERE(Entry Type=FILTER(Output|Negative Adjmt.))?
OK thank you very much
