Request Page
Hi all.
I have one question about req pages. Is it possible to be done save records but only for one control from the page, not for all controls.
ex: when i run report for the second… time some of the controls(only filters) should have the value from the previous run, but other control should have default values(not from the last run,and because of that I can’t use ‘Save Values’ properties.
Thanks a lot,in advance
You can use SaveValues but then set the values of the controls to the default value in the “OnInit” trigger of the Request Page.
Hi Alen,
Did you try out my suggestion? Did it help you?
The members and moderators here on DUG use our spare time and help you for free, all we ask in return is that you spent a few seconds to let us know if we helped you solve your problem.
If any of the suggestions helped you solve your question/problem, then please click the “Verify Solution” on the answer that helped you, so that we can see that your problem is now “resolved”. Otherwise let us know how if there is something else you like to know.
Have a nice day! [:)]
