I have a request page where I have option field(From a table wit values: Active, inactive).
My probleem is that I can’t figuure out the way how to write a code, what displays an error message when user selects Inactive from the option string.
Example:
user opens report. Request page pops up, if user chooses Active option value, then everyting will be okei and he/she can preview the report, but when user select Inactive option value, then error message will pop up.
Not 100% sure if you are talking about the “Option” request page part, or the filter pane below:
If you are talking about the filter pane where the user can select from the list of fields to filter from, you have two options:
Set the TableView for the dataitem to active only (“OptionField”=CONST(Active))
Or raise an error in the “OnPreReport” section of the report for the following case:
YourTable.YourOptionField := YourTable.YourOptionField::Inactive;
IF STRSPOS(YourTable.GETFILTER(YourOptionField), FORMAT(YourOptionField)) > 0 THEN // "Inactive option found in filter
ERROR(‘Cannot use Inactive’);
