In a report, I want to print one record , if that record has a field value = request filter field thar user put on report request filter field.
How can I do It?
How can I do It?
The report will automatically filter based on the request filter field values
Not on this case.
In his report, the line record section is the roundLoop body, on a variable DataItem like integer,so how can I do my report filter if dataitem is Integer?
I am working on standard report 202.
I didnt get ur requirement exactly…
can u explain what r u trying to achieve?
make the filter in SalesLine, or SalesHeader. that ‘integer’ is for report presentation and accommodate nested processing.
