I have table test1 in that Noyes is a Boolean field i display only if check box is true in report? in which method i write the code?please suggest as early as possible
Thanks Advanced.
Thanks Advanced.
write init method to filter on check box yes
hi ,
If u want to filter data on report,
U can write a query by adding range on the noYes field and query value as NoYes::Yes
