Reports
hi,
I want to print the section footer irespective of wheher there is a data in body section or not
or
I want report footer
is it possible ???
please reply me .
Thanks in advance
Jolly,
This is the default behaviour of the system.
Check if PrintOnlyIfDetail property for the dataitem is NO. By default it is NO.
you need to use Integer data item
Thanx , but i m begineer so i dont no how can i use integer section plz help me out.
I want to print some static field at and of report so is there other solution for that???
Hi Jolly,
Add a dataitem to the end report for table Integer and filter to Number=1
This will print a body section for the Integer dataitem once where you can add in the static field(s). Look at the standard sales invoice for an example.
Hi DaveT
Thankx.
I got solution. [:)]
You know any book which can help me caz i m totally new in navision.
If you are a microsoft partner, then you can download some of the document from partnersource, there is a good pdf document called Application Designer’s Guide that is really good for beginners.
If you want to buy from market, I can recommend you :
Programming Microsoft Dynamics NAV
By David Studebaker (Author)
PS: You can get it from Mumbai bookshop, that will be cheaper around 380 Rupees, I was not aware of that and ended up spending more than 2000 rupees and got it shipped from US/ UK.
You can buy from this website @380 INR:
www.cb-india.com
Programming Microsoft Dynamics NAV: Create, Modify And Maintain Applications In NAV 5.0, The Latest Version Of The ERP Application Formerly Known As Navision
by David Studebaker
List Price: Rs.475.00
Net Price: Rs.380.00
You Save: 20%
In Stock
Usually ships within 2-3 Days
HI
Make sure that your “PrintOnlyIfDetail” poerty of you header data item “No” and also check the following on
Make sure that "Print OnEveryPage" poerty of your footer is “Yes” (its not mandatory)
