And are you calling the method? Debug the code if needed…
After i change in the Controller class, i just tried to generate invoice document from AllFreeTextinvoices form Document>View>Original. before that i kept break point after the line i added in controller class. once the break point passed i can see in the Locals debug window, the Report name as the design name i changed. but at the end it generated the default report. Is anywhere else i need to modify?
I did your debugging for you and found that the value is taken from print management setup in FormLetterReport.loadPrintSettings().
Thanks for debugging for me. Is there any possibility i can change the settings from code.
Of course that you can go and change the code.
i am unable to find which class or method the line FormLetterReport.loadPrintSettings() exists. Can you please point me.
It’s loadPrintSettings() method in FormLetterReport class.
I tried debugging multiple times. the control doesn’t get into loadPrintSettings.LoadPrintSettings(). Am i missing something here? Please reply. Thanks
I’m sorry, but I can only tell you what happens in my system, not what’s in yours.
So do the thing I thought you would do a while ago - start debugging the controller (everything in the startOperation()) method) until you find where the report design (that you specified in main()) gets overwritten. When I did it, I found the culprit in loadPrintSettings().
Thanks martin for your help. the below blog helped me to change the design from the default.
https://axfactory.wordpress.com/tag/x-ssrs-reports-print-management/
