Reports-Programmable Section
I need Example for reports which are been created using Programmable section.
Regards’
Kalpna
Right-click Reports node in AOT, choose Find, change Search to All nodes, fill ProgrammableSection into Named field, click Find now and wait.
Thanx Martin .
Hi,To use a simple programmable section,
In fetch method, do the calculation and save the value in a variable…Now you have to use the following code,
element.execute(control number of the programmable section you have created).
In your programmable section, write a display method and drag and drop the conmtrol
thats it…
