reports in aot
hello sir\mdam
this is reports
invoiceid
date
taxamount
invoiceamount
101
12-12-2013
105
1250
101
13-12-2013
214
1520
i want add both amount in a 101 id how i can do this
example
invoiceid taxamount invocieamount date
101 319 2770 anyone
i want output this type
thanks and regards
ali
Hi Ali,
Please use display method in the design body section.
And drag and drop that method in the design.
Please also add invoice id in the group by section.
For example:
display Amount SumInvoiceAmount()
InvoiceTable invoiceTable;
select sum(InvoiceAmount) from invoiceTable
where invoiceTable.InvoiceId == invoiceTable_1.InvoiceId;
return invoiceTable.InvoiceAmount;
same method for invoice date, here i have displayed first date
display TransDate InvoiceDate()
select firstonly InvoiceDate from invoiceTable
order by invoiceTable.InvoiceDate
where invoiceTable.InvoiceId == InvoiceTable_1.InvoiceId;
return invoiceTable.InvoiceDate;
Hari
In general, you want a query like this: select sum(InvoiceAmount), sum(TaxAmount) from t group by InvoiceId.
The implementation depends on the type of your report. If you say “reports in aot”, do you mean a MorphX report (in AX 2009 or older)? In that case, you can model your query directly in your report (under Data Sources) - add InvoiceId to Group By node and aggregate amounts by right-clicking Fields node, choosing New > SUM and selecting the right field.
Sir this method work properly
but on All id print same amount not different print
example
id amount
101 500
102 500
this type
You’ll have to tell us what you implemented.
Dear martin sir
i want implement different id with different amount but my result show
id taxamount invoiceamount
101 254 6523
102 254 6523
this type
but i want different amount with different id
how
thanks
ali
