Dear All
I installed Ax2012 reporting services successfully.but i am unable to deploy the reports
Below error comes
Importing AxUtilLib
Importing AxUtilLib.PowerShell
Importing Microsoft.Dynamics.Administration
Importing Microsoft.Dynamics.AX.Framework.Management
PS C:\Windows\system32> Publish-AXReport -ReportName CustTransList, CustTransOpe
nPerDate
Deploying reports and related artifacts.
AOSName : 01@XXXXXX
ConfigurationId : XXXXXXXX-LTMSSQLSERVER
Description :
Default : True
ReportServerFolder : DynamicsAX
ReportServerName : XXXXXXXX
ReportServerInstanceName : MSSQLSERVER
ReportServerManagerUrl : http://XXXXXXX/Reports
ReportServerWebServiceUrl : http://XXXXXX/ReportServer
Publish-AXReport : An error occurred : The network path was not found.
If User Account Control (UAC) is enabled on the machine, close the application,
right-click the application, and then click Run as administrator.
At line:1 char:17
+ Publish-AXReport <<<< -ReportName CustTransList, CustTransOpenPerDate
+ CategoryInfo : InvalidOperation: (Microsoft.Dynam…erConfigura
tion:VerifyReportServerConfiguration) [Publish-AXReport], InvalidOperation
Exception
+ FullyQualifiedErrorId : An error occurred : The network path was not fou
nd.
tion, right-click the application, and then click Run as administrator.,Mi
crosoft.Dynamics.AX.Framework.Management.Reports.PublishReportCommand
Publish-AXReport : The deployment was aborted. You do not have privileges to de
ploy to server: XXXXXXXX. For deployment, you must have administrative ri
ghts to the SQL Server Reporting Services (SSRS) server. Contact your administr
ator to deploy.
At line:1 char:17
+ CategoryInfo : NotSpecified: (Microsoft.Dynam…ReportsDeployer
:ReportsDeployer) [Publish-AXReport], SecurityException
+ FullyQualifiedErrorId : The deployment was aborted. You do not have priv
ileges to deploy to server: XXXXXXX. For deployment, you must have
administrative rights to the SQL Server Reporting Services (SSRS) server.
Contact your administrator to deploy.,Microsoft.Dynamics.AX.Framework.Mana
Deployment completed.
I checked the UAC it is disable.and run the power shell as an administrator.but i faced the same error
