I am trying to recreate some of the reports that are setup in Navision for external reporting via web browser. How do I access the underlying code for the reports currently setup in Navision. Is there SQL Code associated with it?
There isn’t SQL code associated with the report in the way SRS uses SQL, but there are SQL calls that you can capture via Client Monitor (not the recommended way to go).
Instead, you should go to the Report Designer (click Ctrl+F2 while on the Report) if it is in your license. If it is not in your license, you will have to ask your partner for help.
Clicking on View, Sections will give you an idea of how the report is laid out. Clicking on each dataitem and hitting F9 for C/AL Code will let you see what code gets executed. Frankly, I don’t think that’s going to be enough – you’re probably going to need your partners helps.
For Report 10045, the standard NAV report is “Customer Listing” not Customer Listing By Rep – so I’m not sure what other modifications have been made to the report. Assuming just the name has changed, you will have no trouble getting this report out of SRS. The tables you will need are Company Information (for the report header info), Customer (for the customer information), and Customer Ledger Entries (for the balance information). To calculate the balance, as of the date you are running the report, simply sum the Customer Ledger Entries where Open = True. If you need to run this report by Rep, you probably want to add a filter to the Salesperson/Purchaser field.
For Report 10062 Top 20 Customers you will first have to calculate a balance or (sales) for each Customer (summing the Customer Ledger Entries as above) and then sort them by Balance.
that makes life easier. i was actually thinking of using a reporting software called DBxtra to run the reports instead of SQL Server Reporting Services. Any thoughts about this.
well, it is one of the cheaper reporting tools and has a web viewer with authentication for users already built and allows for creation of pdf and excel versions of reports with the click of the mouse, which means i can deploy reports alot faster and not need to build an entire framework.
