Reporting Tool
Dear All,
I am developing a new system in NAV 5.0 SP1. My clients need to view reports through queries by themselves.
can anybody suggest me which report generating tools should I use and can we connect it with NAV through ODBC.
Please suggest.
Thanking you all in advance.
SSRS is you best option.
Buy this book, from Rene Gayer (PLEASE DON’T STEAL IT).
http://wiki.dynamicsbook.com/index.php?title=Microsoft_Dynamics_NAV_5.00.01_incl._SQL_Reporting_Services
Thank you David,
But SSRS, I am not developing in SQL server, i am using native database.
Can we do what you said in native database too…
If you are using native, I suggest to move to sql server. Instead of spending the money on reporting tool, suggest to spend it on 64 bit sql server.
You can use N/ODBC – it’s the ODBC driver for the native database.
But Rashed is right - get SQL Server.
if you use Native db, the simplest and easiest tool to deploy is MS Access and/or MS Excel.
simply setup the N/ODBC.
from MS Access, you can get external data - LINK TABLES ; then choose the N/ODBC name.
from MS Excel, you can do Data - Import External Data - New Database Queries ; then choose the n/odbc name ; you have an option to save your queries also for later uses.
don’t you think users are very familiar with Excel and q.b.e (queries)?
