Reporting services installation in ax2012
I installed Ax2012 in my laptop(OS is windows7).I am unable to install Reporting services is it possible to install reporting services in windows7?
Try reducing UAC on your machine. Go to start, search for “UAC” and put the level down, this might resolve your installation issue.
If not please explain your error in more detail.
Hi William,
I check the UAC it is down level.Please see the error log below
=== Setup logging started: 8/8/2012 6:25:15 PM ===
Running file: “C:\Program Files\Microsoft Dynamics AX\60\SetupSupport\AxSetup.exe” RelatedFilesDir=“H:\Ax 2012 Sw\ax2012” AutoRun=1 LogDir=“C:\Program Files\Microsoft Dynamics AX\60\Setup Logs\2012-08-08 18-25-14”
AxSetup version number: 6.0.947.0
Microsoft Windows NT 6.1.7601 Service Pack 1 (64 bit)
SHIVATEJA-LT
B2BSOFTECH\shivateja
Interactive: True
2012-08-08 18:25:15Z RelatedFilesDir=H:\Ax 2012 Sw\ax2012
2012-08-08 18:25:15Z LogDir=C:\Program Files\Microsoft Dynamics AX\60\Setup Logs\2012-08-08 18-25-14
2012-08-08 18:25:15Z Property RelatedFilesDir set to: ‘H:\Ax 2012 Sw\ax2012’
2012-08-08 18:25:15Z Property LogDir set to: ‘C:\Program Files\Microsoft Dynamics AX\60\Setup Logs\2012-08-08 18-25-14’
2012-08-08 18:25:15Z Common Property Install Path set to ‘C:\Program Files\Microsoft Dynamics AX\60’.
2012-08-08 18:25:15Z Installation Path retrieved from registry. Value: ‘C:\Program Files\Microsoft Dynamics AX\60’
2012-08-08 18:25:15Z Initializing log file: C:\Program Files\Microsoft Dynamics AX\60\Setup Logs\2012-08-08 18-25-14\DynamicsSetupLog.txt
2012-08-08 18:25:15Z === Starting evaluation of existing installation state ===
2012-08-08 18:25:15Z Application Object Server instance 01 has been installed with the name 01-AX2012Local.
2012-08-08 18:25:15Z MSI file: Components64.msi Installed: True
2012-08-08 18:25:15Z MSI file: HelpServer64.msi Installed: False
2012-08-08 18:25:15Z MSI file: ClientOba64.msi Installed: True
2012-08-08 18:25:15Z MSI file: TraceParser.msi Installed: True
2012-08-08 18:25:15Z Previously Installed Component: Application Object Server (AOS) (01-AX2012Local)
2012-08-08 18:25:15Z Previously Installed Component: Management utilities
2012-08-08 18:25:15Z Previously Installed Component: .NET Business Connector
2012-08-08 18:25:15Z Previously Installed Component: Debugger
2012-08-08 18:25:15Z Previously Installed Component: Visual Studio Tools
2012-08-08 18:25:15Z Property RunMode set to: ‘AddRemoveFeatures’
2012-08-08 18:25:15Z === Starting UI phase ===
2012-08-08 18:25:15Z S030WelcomeInfo
2012-08-08 18:25:17Z S040MaintenanceMode
2012-08-08 18:25:21Z Property RemoveComponents set to: ‘0’
2012-08-08 18:25:21Z S080FeatureOption
2012-08-08 18:25:22Z Property BypassWarnings set to: ‘0’
2012-08-08 18:25:27Z Property InstallDatabase set to: ‘1’
2012-08-08 18:25:29Z Property InstallReportingServicesExtensions set to: ‘1’
2012-08-08 18:25:34Z Property ClientLanguage set to: ‘EN-US’
2012-08-08 18:25:34Z Property AosPort set to: ‘2712’
2012-08-08 18:25:34Z Property ClientAosServer set to: ‘SHIVATEJA-LT’
2012-08-08 18:25:35Z S640InitialPrerequisites
2012-08-08 18:25:35Z Loading data table ‘Microsoft.Dynamics.Setup.PrereqAssembly.PRRESXMAP.xml’.
2012-08-08 18:25:35Z Loading data table ‘Microsoft.Dynamics.Setup.PrereqAssembly.PRPRCMAP.xml’.
2012-08-08 18:25:35Z Loading data table ‘Microsoft.Dynamics.Setup.PrereqAssembly.PRCAMAP.xml’.
2012-08-08 18:25:35Z Loading data table ‘Microsoft.Dynamics.Setup.PrereqAssembly.COMPPRMAP.xml’.
2012-08-08 18:25:35Z Loading data table ‘Microsoft.Dynamics.Setup.PrereqAssembly.COMPDATA.xml’.
2012-08-08 18:25:35Z Loading prerequisites for component ‘’:
2012-08-08 18:25:35Z Computer restart pending
2012-08-08 18:25:35Z Microsoft .NET Framework 3.5 Service Pack 1
2012-08-08 18:25:35Z Domain user account
2012-08-08 18:25:35Z Local administrator
2012-08-08 18:25:35Z Microsoft Windows Installer
2012-08-08 18:25:35Z Adding prerequisite ‘Computer restart pending’.
2012-08-08 18:25:35Z Adding prerequisite ‘Microsoft .NET Framework 3.5 Service Pack 1’.
2012-08-08 18:25:35Z Adding prerequisite ‘Domain user account’.
2012-08-08 18:25:35Z Adding prerequisite ‘Local administrator’.
2012-08-08 18:25:35Z Adding prerequisite ‘Microsoft Windows Installer’.
2012-08-08 18:25:35Z Loading prerequisites for component ‘Databases’:
2012-08-08 18:25:35Z Loading prerequisites for component ‘Reporting Services extensions’:
2012-08-08 18:25:35Z Server operating system
2012-08-08 18:25:35Z Microsoft .NET Framework 4.0
2012-08-08 18:25:35Z Microsoft SQL Server Reporting Services
2012-08-08 18:25:35Z Required updates for Microsoft SQL Server
2012-08-08 18:25:35Z Microsoft SQL Server Reporting Services started
2012-08-08 18:25:35Z Microsoft SQL Server Reporting Services web service
2012-08-08 18:25:35Z Microsoft Visual C++ 2008 SP1 Redistributable (x86)
2012-08-08 18:25:35Z Microsoft Visual C++ 2008 SP1 Redistributable (x64)
2012-08-08 18:25:35Z Windows Identity Foundation
2012-08-08 18:25:35Z Adding prerequisite ‘Server operating system’.
2012-08-08 18:25:35Z Adding prerequisite ‘Microsoft .NET Framework 4.0’.
2012-08-08 18:25:35Z Adding prerequisite ‘Microsoft SQL Server Reporting Services’.
2012-08-08 18:25:35Z Adding prerequisite ‘Required updates for Microsoft SQL Server’.
2012-08-08 18:25:35Z Adding prerequisite ‘Microsoft SQL Server Reporting Services started’.
2012-08-08 18:25:35Z Adding prerequisite ‘Microsoft SQL Server Reporting Services web service’.
2012-08-08 18:25:35Z Adding prerequisite ‘Microsoft Visual C++ 2008 SP1 Redistributable (x86)’.
2012-08-08 18:25:35Z Adding prerequisite ‘Microsoft Visual C++ 2008 SP1 Redistributable (x64)’.
2012-08-08 18:25:35Z Adding prerequisite ‘Windows Identity Foundation’.
2012-08-08 18:25:35Z H:\Ax 2012 Sw\ax2012
2012-08-08 18:25:35Z Components selected:
2012-08-08 18:25:35Z Databases
2012-08-08 18:25:35Z Reporting Services extensions
2012-08-08 18:25:36Z Domain user account
2012-08-08 18:25:36Z Local administrator
2012-08-08 18:25:36Z Microsoft Windows Installer
2012-08-08 18:25:36Z Adding prerequisite ‘Computer restart pending’.
2012-08-08 18:25:36Z Adding prerequisite ‘Microsoft .NET Framework 3.5 Service Pack 1’.
2012-08-08 18:25:36Z Adding prerequisite ‘Domain user account’.
2012-08-08 18:25:36Z Adding prerequisite ‘Local administrator’.
2012-08-08 18:25:36Z Adding prerequisite ‘Microsoft Windows Installer’.
2012-08-08 18:25:36Z Loading prerequisites for component ‘Databases’:
2012-08-08 18:25:36Z Computer restart pending
2012-08-08 18:25:36Z Microsoft .NET Framework 3.5 Service Pack 1
2012-08-08 18:25:36Z Loading prerequisites for component ‘Reporting Services extensions’:
2012-08-08 18:25:36Z Server operating system
2012-08-08 18:25:36Z Microsoft .NET Framework 4.0
2012-08-08 18:25:36Z Microsoft SQL Server Reporting Services
2012-08-08 18:25:36Z Required updates for Microsoft SQL Server
2012-08-08 18:25:36Z Microsoft SQL Server Reporting Services started
2012-08-08 18:25:36Z Microsoft SQL Server Reporting Services web service
2012-08-08 18:25:36Z Microsoft Visual C++ 2008 SP1 Redistributable (x86)
2012-08-08 18:25:36Z Microsoft Visual C++ 2008 SP1 Redistributable (x64)
2012-08-08 18:25:36Z Windows Identity Foundation
2012-08-08 18:25:36Z Adding prerequisite ‘Server operating system’.
2012-08-08 18:25:36Z Adding prerequisite ‘Microsoft .NET Framework 4.0’.
2012-08-08 18:25:36Z Adding prerequisite ‘Microsoft SQL Server Reporting Services’.
2012-08-08 18:25:36Z Adding prerequisite ‘Required updates for Microsoft SQL Server’.
2012-08-08 18:25:36Z Adding prerequisite ‘Microsoft SQL Server Reporting Services started’.
2012-08-08 18:25:36Z Adding prerequisite ‘Microsoft SQL Server Reporting Services web service’.
2012-08-08 18:25:36Z Adding prerequisite ‘Microsoft Visual C++ 2008 SP1 Redistributable (x86)’.
2012-08-08 18:25:36Z Adding prerequisite ‘Microsoft Visual C++ 2008 SP1 Redistributable (x64)’.
2012-08-08 18:25:36Z Adding prerequisite ‘Windows Identity Foundation’.
2012-08-08 18:25:36Z Checking the following prerequisites:
2012-08-08 18:25:36Z Performing a computer restart pending check for prerequisite ‘Computer restart pending’.
2012-08-08 18:25:36Z Check succeeded.
2012-08-08 18:25:36Z Performing a registry value version check for prerequisite ‘Microsoft .NET Framework 3.5 Service Pack 1’.
2012-08-08 18:25:36Z Searching for a minimum version of ‘3.5.30729.1’.
2012-08-08 18:25:36Z Version found: ‘3.5.30729.5420’.
2012-08-08 18:25:36Z Performing a domain account check for prerequisite ‘Domain user account’.
2012-08-08 18:25:36Z Performing a local administrator check for prerequisite ‘Local administrator’.
2012-08-08 18:25:36Z Performing a windows installer version check for prerequisite ‘Microsoft Windows Installer’.
2012-08-08 18:25:36Z Searching for a minimum version of ‘3.0.0.0’.
2012-08-08 18:25:36Z Version found: ‘5.0.7601.17807’.
2012-08-08 18:25:36Z Performing an OS version check for prerequisite ‘Server operating system’.
2012-08-08 18:25:37Z Searching for a minimum version of ‘6.0.1.0’ and a suggested version of ‘6.0.1.0’.
2012-08-08 18:25:37Z Version found: ‘6.1.7601.0’.
2012-08-08 18:25:37Z Check succeeded.
2012-08-08 18:25:37Z Success
2012-08-08 18:25:37Z Performing a .NET version check for prerequisite ‘Microsoft .NET Framework 4.0’.
2012-08-08 18:25:37Z Searching for a minimum version of ‘4.0.30319.0’.
2012-08-08 18:25:37Z Version found: ‘4.0.30319.0’.
2012-08-08 18:25:37Z Checking for the existence of the registry key ‘HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft.NetFramework\v4.0.30319\SKUs.NETFramework,Version=v4.0’.
2012-08-08 18:25:37Z Performing a Microsoft SQLServer Reporting Services existence check for prerequisite ‘Microsoft SQL Server Reporting Services’.
2012-08-08 18:25:37Z 10.50.2500.0
2012-08-08 18:25:37Z MSSQLSERVER
2012-08-08 18:25:37Z Performing a Microsoft SQLServer CU3 check for prerequisite ‘Required updates for Microsoft SQL Server’.
2012-08-08 18:25:37Z Performing a Microsoft SQLServer Reporting Services status check for prerequisite ‘Microsoft SQL Server Reporting Services started’.
2012-08-08 18:25:37Z Performing a Microsoft SQLServer Reporting Services URL check for prerequisite ‘Microsoft SQL Server Reporting Services web service’.
2012-08-08 18:25:37Z Looking for website ‘http://shivateja-lt/ReportServer’.
2012-08-08 18:26:05Z Check succeeded.
2012-08-08 18:26:05Z Performing an MSI package check for prerequisite ‘Microsoft Visual C++ 2008 SP1 Redistributable (x86)’.
2012-08-08 18:26:05Z Checking for installed MSI’s with an upgrade code ‘{AA783A14-A7A3-3D33-95F0-9A351D530011}’.
2012-08-08 18:26:05Z Searching for a minimum version of ‘9.0.30729.0’.
2012-08-08 18:26:05Z Version found: ‘9.0.30729.0’.
2012-08-08 18:26:05Z Success
2012-08-08 18:26:05Z Performing an MSI package check for prerequisite ‘Microsoft Visual C++ 2008 SP1 Redistributable (x64)’.
2012-08-08 18:26:10Z S161InstallModelDatabaseTypeOption
2012-08-08 18:26:15Z Property InstallDatabase set to: ‘2’
2012-08-08 18:26:15Z S163ModelSqlDatabaseNameSelection
2012-08-08 18:26:15Z Property DbSqlServer set to: ‘SHIVATEJA-LT’
2012-08-08 18:26:25Z Property DbSqlDatabaseName set to: ‘AX2012Local’
2012-08-08 18:26:25Z Property DbSqlModelStoreBaseline set to: ‘AX2012LocalBaseline’
2012-08-08 18:26:25Z Property UpgradeDB set to: ‘0’
2012-08-08 18:26:25Z S620ModelSelection
2012-08-08 18:26:52Z Model Process Manufacturing (Microsoft Corporation) not found.
2012-08-08 18:26:52Z Model Process Manufacturing Upgrade (Microsoft Corporation) not found.
2012-08-08 18:26:52Z Model Public Sector (Microsoft Corporation) not found.
2012-08-08 18:26:52Z Model Project Management Upgrade (Microsoft Corporation) not found.
2012-08-08 18:26:53Z Model Project Management Upgrade (Microsoft Corporation) not found.
2012-08-08 18:26:53Z Model Process Manufacturing (Microsoft Corporation) not found.
2012-08-08 18:26:53Z Model Process Manufacturing Upgrade (Microsoft Corporation) not found.
2012-08-08 18:26:53Z Model Public Sector (Microsoft Corporation) not found.
2012-08-08 18:26:54Z Model Project Management Upgrade (Microsoft Corporation) not found.
2012-08-08 18:26:54Z Model Process Manufacturing (Microsoft Corporation) not found.
2012-08-08 18:26:54Z Model Process Manufacturing Upgrade (Microsoft Corporation) not found.
2012-08-08 18:26:54Z Model Public Sector (Microsoft Corporation) not found.
2012-08-08 18:26:54Z OPTIONAL model H:\Ax 2012 Sw\ax2012\Models\ProcessIndustries\ProcessManufacturing.axmodel is found.
2012-08-08 18:26:54Z OPTIONAL model H:\Ax 2012 Sw\ax2012\Models\ProcessIndustries\ProcessManufacturingUpgrade.axmodel is found.
2012-08-08 18:26:54Z OPTIONAL model H:\Ax 2012 Sw\ax2012\Models\PublicSector\PublicSector.axmodel is found.
2012-08-08 18:26:54Z OPTIONAL model H:\Ax 2012 Sw\ax2012\Models\ServiceIndustries\ProjectFeaturePackUpgrade.axmodel is found.
2012-08-08 18:26:54Z MANDATORY model H:\Ax 2012 Sw\ax2012\Models\Standard\ProcessManufacturing.axmodel is found.
2012-08-08 18:26:54Z MANDATORY model H:\Ax 2012 Sw\ax2012\Models\Standard\ProcessManufacturingUpgrade.axmodel is found.
2012-08-08 18:26:54Z Already installed OPTIONAL model H:\Ax 2012 Sw\ax2012\Models\Labels\FoundationLabels.axmodel is found.
2012-08-08 18:26:54Z Already installed OPTIONAL model H:\Ax 2012 Sw\ax2012\Models\ServiceIndustries\ProjectFeaturePack.axmodel is found.
2012-08-08 18:26:54Z Already installed MANDATORY model H:\Ax 2012 Sw\ax2012\Models\Standard\Foundation.axmodel is found.
2012-08-08 18:26:54Z Already installed OPTIONAL model H:\Ax 2012 Sw\ax2012\Models\Upgrade\FoundationUpgrade.axmodel is found.
2012-08-08 18:26:57Z Property AosPort set to: ‘2712’
2012-08-08 18:26:57Z Property AosWsdlPort set to: ‘8101’
2012-08-08 18:26:57Z Property ClientAosServer set to: ‘AX2012Local@SHIVATEJA-LT’
2012-08-08 18:26:57Z S270BCProxyAccountEntry
2012-08-08 18:27:08Z We do not recommend using your account B2BSOFTECH\shivateja for the Business Connector Proxy account. Contact your system administrator to create a dedicated account.
2012-08-08 18:27:08Z Property BusinessConnectorProxyAccount set to: ‘B2BSOFTECH\shivateja’
2012-08-08 18:27:08Z Property BusinessConnectorProxyAccountPassword set to: ‘**********’
2012-08-08 18:27:08Z S580ReportingServerInstance
2012-08-08 18:27:08Z 10.50.2500.0
2012-08-08 18:27:08Z MSSQLSERVER
2012-08-08 18:27:11Z Property ReportingServicesInstance set to: ‘MSSQLSERVER’
2012-08-08 18:27:11Z Property DeployReports set to: ‘1’
2012-08-08 18:27:11Z Loading prerequisites for component ‘’:
2012-08-08 18:27:11Z Computer restart pending
2012-08-08 18:27:11Z Microsoft .NET Framework 3.5 Service Pack 1
2012-08-08 18:27:11Z Domain user account
2012-08-08 18:27:11Z Local administrator
2012-08-08 18:27:11Z Microsoft Windows Installer
2012-08-08 18:27:11Z Adding prerequisite ‘Computer restart pending’.
2012-08-08 18:27:11Z Adding prerequisite ‘Microsoft .NET Framework 3.5 Service Pack 1’.
2012-08-08 18:27:11Z Adding prerequisite ‘Domain user account’.
2012-08-08 18:27:11Z Adding prerequisite ‘Local administrator’.
2012-08-08 18:27:11Z Adding prerequisite ‘Microsoft Windows Installer’.
2012-08-08 18:27:11Z Loading prerequisites for component ‘Databases’:
2012-08-08 18:27:11Z Microsoft SQL Server Full-Text Search
2012-08-08 18:27:11Z SQL Server Full-text Filter Daemon Launcher service startup type
2012-08-08 18:27:11Z SQL Server Full-text Filter Daemon Launcher service started
2012-08-08 18:27:11Z Adding prerequisite ‘Microsoft SQL Server Full-Text Search’.
2012-08-08 18:27:11Z Adding prerequisite ‘SQL Server Full-text Filter Daemon Launcher service startup type’.
2012-08-08 18:27:11Z Adding prerequisite ‘SQL Server Full-text Filter Daemon Launcher service started’.
2012-08-08 18:27:11Z Adding prerequisite ‘Microsoft SQL Server (Databases)’.
2012-08-08 18:27:11Z Loading prerequisites for component ‘Reporting Services extensions’:
2012-08-08 18:27:11Z Server operating system
2012-08-08 18:27:12Z Application Object Server (AOS) Services WSDL URI accessible
2012-08-08 18:27:12Z Microsoft .NET Framework 4.0
2012-08-08 18:27:12Z Microsoft SQL Server Reporting Services
2012-08-08 18:27:12Z Required updates for Microsoft SQL Server
2012-08-08 18:27:12Z Microsoft SQL Server Reporting Services started
2012-08-08 18:27:12Z Microsoft SQL Server Reporting Services web service
2012-08-08 18:27:12Z Microsoft Visual C++ 2008 SP1 Redistributable (x86)
2012-08-08 18:27:12Z Microsoft Visual C++ 2008 SP1 Redistributable (x64)
2012-08-08 18:27:12Z Windows Identity Foundation
2012-08-08 18:27:12Z Adding prerequisite ‘Server operating system’.
2012-08-08 18:27:12Z Adding prerequisite ‘Application Object Server (AOS) Services WSDL URI accessible’.
2012-08-08 18:27:12Z Adding prerequisite ‘Microsoft .NET Framework 4.0’.
2012-08-08 18:27:12Z Adding prerequisite ‘Microsoft SQL Server Reporting Services’.
2012-08-08 18:27:12Z Adding prerequisite ‘Required updates for Microsoft SQL Server’.
2012-08-08 18:27:12Z Adding prerequisite ‘Microsoft SQL Server Reporting Services started’.
2012-08-08 18:27:12Z Adding prerequisite ‘Microsoft SQL Server Reporting Services web service’.
2012-08-08 18:27:12Z Adding prerequisite ‘Microsoft Visual C++ 2008 SP1 Redistributable (x86)’.
2012-08-08 18:27:12Z Adding prerequisite ‘Microsoft Visual C++ 2008 SP1 Redistributable (x64)’.
2012-08-08 18:27:12Z Adding prerequisite ‘Windows Identity Foundation’.
2012-08-08 18:27:12Z S630Prerequisites
2012-08-08 18:27:12Z H:\Ax 2012 Sw\ax2012
2012-08-08 18:27:12Z Components selected:
2012-08-08 18:27:12Z Databases
2012-08-08 18:27:12Z Reporting Services extensions
2012-08-08 18:27:12Z Loading prerequisites for component ‘’:
2012-08-08 18:27:12Z Computer restart pending
2012-08-08 18:27:12Z Microsoft .NET Framework 3.5 Service Pack 1
2012-08-08 18:27:12Z Domain user account
2012-08-08 18:27:12Z Local administrator
2012-08-08 18:27:12Z Microsoft Windows Installer
2012-08-08 18:27:12Z Adding prerequisite ‘Computer restart pending’.
2012-08-08 18:27:12Z Adding prerequisite ‘Microsoft .NET Framework 3.5 Service Pack 1’.
2012-08-08 18:27:12Z Adding prerequisite ‘Domain user account’.
2012-08-08 18:27:12Z Adding prerequisite ‘Local administrator’.
2012-08-08 18:27:12Z Adding prerequisite ‘Microsoft Windows Installer’.
2012-08-08 18:27:12Z Loading prerequisites for component ‘Databases’:
2012-08-08 18:27:13Z Microsoft .NET Framework 3.5 Service Pack 1
2012-08-08 18:27:13Z Microsoft SQL Server Full-Text Search
2012-08-08 18:27:13Z SQL Server Full-text Filter Daemon Launcher service startup type
2012-08-08 18:27:13Z SQL Server Full-text Filter Daemon Launcher service started
2012-08-08 18:27:13Z Adding prerequisite ‘Microsoft SQL Server Full-Text Search’.
2012-08-08 18:27:13Z Adding prerequisite ‘SQL Server Full-text Filter Daemon Launcher service startup type’.
2012-08-08 18:27:13Z Adding prerequisite ‘SQL Server Full-text Filter Daemon Launcher service started’.
2012-08-08 18:27:13Z Adding prerequisite ‘Microsoft SQL Server (Databases)’.
2012-08-08 18:27:13Z Loading prerequisites for component ‘Reporting Services extensions’:
2012-08-08 18:27:13Z Computer restart pending
2012-08-08 18:27:13Z Server operating system
2012-08-08 18:27:13Z Application Object Server (AOS) Services WSDL URI accessible
2012-08-08 18:27:13Z Microsoft .NET Framework 4.0
2012-08-08 18:27:13Z Microsoft SQL Server Reporting Services
2012-08-08 18:27:13Z Required updates for Microsoft SQL Serv
Dear William,
I checked the UAC it is in down level.Please see the below error log.
SHIVATEJA-LT
Interactive: True
Hi William,
I checked the UAC it is in down level.Please find the error log below
=== Setup logging started: 8/8/2012 6:46:11 PM ===
Running file: “C:\Program Files\Microsoft Dynamics AX\60\SetupSupport\AxSetup.exe” RelatedFilesDir=“H:\Ax 2012 Sw\ax2012” AutoRun=1 LogDir=“C:\Program Files\Microsoft Dynamics AX\60\Setup Logs\2012-08-08 18-46-11”
SHIVATEJA-LT
Interactive: True
2012-08-08 18:46:11Z RelatedFilesDir=H:\Ax 2012 Sw\ax2012
2012-08-08 18:46:11Z LogDir=C:\Program Files\Microsoft Dynamics AX\60\Setup Logs\2012-08-08 18-46-11
2012-08-08 18:46:11Z Property RelatedFilesDir set to: ‘H:\Ax 2012 Sw\ax2012’
2012-08-08 18:46:11Z Property LogDir set to: ‘C:\Program Files\Microsoft Dynamics AX\60\Setup Logs\2012-08-08 18-46-11’
2012-08-08 18:46:11Z Common Property Install Path set to ‘C:\Program Files\Microsoft Dynamics AX\60’.
2012-08-08 18:46:11Z Installation Path retrieved from registry. Value: ‘C:\Program Files\Microsoft Dynamics AX\60’
2012-08-08 18:46:11Z Initializing log file: C:\Program Files\Microsoft Dynamics AX\60\Setup Logs\2012-08-08 18-46-11\DynamicsSetupLog.txt
2012-08-08 18:46:11Z === Starting evaluation of existing installation state ===
2012-08-08 18:46:11Z Application Object Server instance 01 has been installed with the name 01-AX2012Local.
2012-08-08 18:46:11Z MSI file: Components64.msi Installed: True
2012-08-08 18:46:11Z MSI file: HelpServer64.msi Installed: False
2012-08-08 18:46:11Z MSI file: ClientOba64.msi Installed: True
2012-08-08 18:46:11Z MSI file: TraceParser.msi Installed: True
2012-08-08 18:46:11Z Previously Installed Component: Application Object Server (AOS) (01-AX2012Local)
2012-08-08 18:46:11Z Previously Installed Component: Management utilities
2012-08-08 18:46:11Z Previously Installed Component: .NET Business Connector
2012-08-08 18:46:11Z Previously Installed Component: Debugger
2012-08-08 18:46:11Z Previously Installed Component: Visual Studio Tools
2012-08-08 18:46:11Z Property RunMode set to: ‘AddRemoveFeatures’
2012-08-08 18:46:11Z === Starting UI phase ===
2012-08-08 18:46:12Z S030WelcomeInfo
2012-08-08 18:46:14Z S040MaintenanceMode
2012-08-08 18:46:17Z Property RemoveComponents set to: ‘0’
2012-08-08 18:46:17Z S080FeatureOption
2012-08-08 18:46:18Z Property BypassWarnings set to: ‘0’
2012-08-08 18:46:20Z Property InstallReportingServicesExtensions set to: ‘1’
2012-08-08 18:46:23Z Property ClientLanguage set to: ‘EN-US’
2012-08-08 18:46:23Z Property AosPort set to: ‘2712’
2012-08-08 18:46:23Z Property ClientAosServer set to: ‘SHIVATEJA-LT’
2012-08-08 18:46:24Z Property AosPort set to: ‘2712’
2012-08-08 18:46:24Z Property AosWsdlPort set to: ‘8101’
2012-08-08 18:46:24Z Property ClientAosServer set to: ‘AX2012Local@SHIVATEJA-LT’
2012-08-08 18:46:24Z S640InitialPrerequisites
2012-08-08 18:46:24Z Loading data table ‘Microsoft.Dynamics.Setup.PrereqAssembly.PRRESXMAP.xml’.
2012-08-08 18:46:24Z Loading data table ‘Microsoft.Dynamics.Setup.PrereqAssembly.PRPRCMAP.xml’.
2012-08-08 18:46:24Z Loading data table ‘Microsoft.Dynamics.Setup.PrereqAssembly.PRCAMAP.xml’.
2012-08-08 18:46:24Z Loading data table ‘Microsoft.Dynamics.Setup.PrereqAssembly.COMPPRMAP.xml’.
2012-08-08 18:46:24Z Loading data table ‘Microsoft.Dynamics.Setup.PrereqAssembly.COMPDATA.xml’.
2012-08-08 18:46:24Z Loading prerequisites for component ‘’:
2012-08-08 18:46:24Z Computer restart pending
2012-08-08 18:46:24Z Microsoft .NET Framework 3.5 Service Pack 1
2012-08-08 18:46:24Z Domain user account
2012-08-08 18:46:24Z Local administrator
2012-08-08 18:46:24Z Microsoft Windows Installer
2012-08-08 18:46:24Z Adding prerequisite ‘Computer restart pending’.
2012-08-08 18:46:24Z Adding prerequisite ‘Microsoft .NET Framework 3.5 Service Pack 1’.
2012-08-08 18:46:24Z Adding prerequisite ‘Domain user account’.
2012-08-08 18:46:24Z Adding prerequisite ‘Local administrator’.
2012-08-08 18:46:24Z Adding prerequisite ‘Microsoft Windows Installer’.
2012-08-08 18:46:24Z Loading prerequisites for component ‘Reporting Services extensions’:
2012-08-08 18:46:24Z Server operating system
2012-08-08 18:46:24Z Microsoft .NET Framework 4.0
2012-08-08 18:46:24Z Microsoft SQL Server Reporting Services
2012-08-08 18:46:24Z Required updates for Microsoft SQL Server
2012-08-08 18:46:24Z Microsoft SQL Server Reporting Services started
2012-08-08 18:46:24Z Microsoft SQL Server Reporting Services web service
2012-08-08 18:46:24Z Microsoft Visual C++ 2008 SP1 Redistributable (x86)
2012-08-08 18:46:24Z Microsoft Visual C++ 2008 SP1 Redistributable (x64)
2012-08-08 18:46:24Z Windows Identity Foundation
2012-08-08 18:46:24Z Adding prerequisite ‘Server operating system’.
2012-08-08 18:46:24Z Adding prerequisite ‘Microsoft .NET Framework 4.0’.
2012-08-08 18:46:24Z Adding prerequisite ‘Microsoft SQL Server Reporting Services’.
2012-08-08 18:46:24Z Adding prerequisite ‘Required updates for Microsoft SQL Server’.
2012-08-08 18:46:24Z Adding prerequisite ‘Microsoft SQL Server Reporting Services started’.
2012-08-08 18:46:24Z Adding prerequisite ‘Microsoft SQL Server Reporting Services web service’.
2012-08-08 18:46:24Z Adding prerequisite ‘Microsoft Visual C++ 2008 SP1 Redistributable (x86)’.
2012-08-08 18:46:24Z Adding prerequisite ‘Microsoft Visual C++ 2008 SP1 Redistributable (x64)’.
2012-08-08 18:46:24Z Adding prerequisite ‘Windows Identity Foundation’.
2012-08-08 18:46:24Z H:\Ax 2012 Sw\ax2012
2012-08-08 18:46:24Z Components selected:
2012-08-08 18:46:24Z Reporting Services extensions
2012-08-08 18:46:25Z Microsoft Windows Installer
2012-08-08 18:46:25Z Adding prerequisite ‘Computer restart pending’.
2012-08-08 18:46:25Z Adding prerequisite ‘Microsoft .NET Framework 3.5 Service Pack 1’.
2012-08-08 18:46:25Z Adding prerequisite ‘Domain user account’.
2012-08-08 18:46:25Z Adding prerequisite ‘Local administrator’.
2012-08-08 18:46:25Z Adding prerequisite ‘Microsoft Windows Installer’.
2012-08-08 18:46:25Z Loading prerequisites for component ‘Reporting Services extensions’:
2012-08-08 18:46:25Z Computer restart pending
2012-08-08 18:46:25Z Microsoft .NET Framework 3.5 Service Pack 1
2012-08-08 18:46:25Z Server operating system
2012-08-08 18:46:25Z Microsoft .NET Framework 4.0
2012-08-08 18:46:25Z Microsoft SQL Server Reporting Services
2012-08-08 18:46:25Z Required updates for Microsoft SQL Server
2012-08-08 18:46:25Z Microsoft SQL Server Reporting Services started
2012-08-08 18:46:25Z Microsoft SQL Server Reporting Services web service
2012-08-08 18:46:25Z Microsoft Visual C++ 2008 SP1 Redistributable (x86)
2012-08-08 18:46:25Z Microsoft Visual C++ 2008 SP1 Redistributable (x64)
2012-08-08 18:46:25Z Windows Identity Foundation
2012-08-08 18:46:25Z Adding prerequisite ‘Server operating system’.
2012-08-08 18:46:25Z Adding prerequisite ‘Microsoft .NET Framework 4.0’.
2012-08-08 18:46:25Z Adding prerequisite ‘Microsoft SQL Server Reporting Services’.
2012-08-08 18:46:25Z Adding prerequisite ‘Required updates for Microsoft SQL Server’.
2012-08-08 18:46:25Z Adding prerequisite ‘Microsoft SQL Server Reporting Services started’.
2012-08-08 18:46:25Z Adding prerequisite ‘Microsoft SQL Server Reporting Services web service’.
2012-08-08 18:46:25Z Adding prerequisite ‘Microsoft Visual C++ 2008 SP1 Redistributable (x86)’.
2012-08-08 18:46:25Z Adding prerequisite ‘Microsoft Visual C++ 2008 SP1 Redistributable (x64)’.
2012-08-08 18:46:25Z Adding prerequisite ‘Windows Identity Foundation’.
2012-08-08 18:46:25Z Checking the following prerequisites:
2012-08-08 18:46:25Z Performing a computer restart pending check for prerequisite ‘Computer restart pending’.
2012-08-08 18:46:25Z Check failed.
2012-08-08 18:46:25Z Resolution: Restart the computer before you install Microsoft Dynamics AX or its prerequisites.
2012-08-08 18:46:25Z For information about how the prerequisite was validated, click the View log file link. For detailed troubleshooting steps, see the troubleshooting section of the Installation Guide at http://go.microsoft.com/fwlink/?LinkId=211990.
2012-08-08 18:46:25Z Performing a registry value version check for prerequisite ‘Microsoft .NET Framework 3.5 Service Pack 1’.
2012-08-08 18:46:25Z Searching for a minimum version of ‘3.5.30729.1’.
2012-08-08 18:46:25Z Version found: ‘3.5.30729.5420’.
2012-08-08 18:46:25Z Check succeeded.
2012-08-08 18:46:25Z Performing a domain account check for prerequisite ‘Domain user account’.
2012-08-08 18:46:25Z Performing a local administrator check for prerequisite ‘Local administrator’.
2012-08-08 18:46:25Z Performing a windows installer version check for prerequisite ‘Microsoft Windows Installer’.
2012-08-08 18:46:25Z Searching for a minimum version of ‘3.0.0.0’.
2012-08-08 18:46:25Z Version found: ‘5.0.7601.17807’.
2012-08-08 18:46:25Z Performing an OS version check for prerequisite ‘Server operating system’.
2012-08-08 18:46:25Z Searching for a minimum version of ‘6.0.1.0’ and a suggested version of ‘6.0.1.0’.
2012-08-08 18:46:25Z Version found: ‘6.1.7601.0’.
2012-08-08 18:46:25Z Success
2012-08-08 18:46:25Z Performing a .NET version check for prerequisite ‘Microsoft .NET Framework 4.0’.
2012-08-08 18:46:25Z Searching for a minimum version of ‘4.0.30319.0’.
2012-08-08 18:46:25Z Version found: ‘4.0.30319.0’.
2012-08-08 18:46:25Z Checking for the existence of the registry key ‘HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft.NetFramework\v4.0.30319\SKUs.NETFramework,Version=v4.0’.
2012-08-08 18:46:25Z Performing a Microsoft SQLServer Reporting Services existence check for prerequisite ‘Microsoft SQL Server Reporting Services’.
2012-08-08 18:46:26Z 10.50.2500.0
2012-08-08 18:46:26Z MSSQLSERVER
2012-08-08 18:46:26Z Check succeeded.
2012-08-08 18:46:26Z Performing a Microsoft SQLServer CU3 check for prerequisite ‘Required updates for Microsoft SQL Server’.
2012-08-08 18:46:26Z Performing a Microsoft SQLServer Reporting Services status check for prerequisite ‘Microsoft SQL Server Reporting Services started’.
2012-08-08 18:46:26Z Performing a Microsoft SQLServer Reporting Services URL check for prerequisite ‘Microsoft SQL Server Reporting Services web service’.
2012-08-08 18:46:26Z Looking for website ‘http://shivateja-lt/ReportServer’.
2012-08-08 18:46:41Z Check succeeded.
2012-08-08 18:46:41Z Performing an MSI package check for prerequisite ‘Microsoft Visual C++ 2008 SP1 Redistributable (x86)’.
2012-08-08 18:46:41Z Checking for installed MSI’s with an upgrade code ‘{AA783A14-A7A3-3D33-95F0-9A351D530011}’.
2012-08-08 18:46:41Z Searching for a minimum version of ‘9.0.30729.0’.
2012-08-08 18:46:41Z Version found: ‘9.0.30729.0’.
2012-08-08 18:46:41Z Success
2012-08-08 18:46:41Z Performing an MSI package check for prerequisite ‘Microsoft Visual C++ 2008 SP1 Redistributable (x64)’.
2012-08-08 18:46:43Z Property AosPort set to: ‘2712’
2012-08-08 18:46:43Z Property AosWsdlPort set to: ‘8101’
2012-08-08 18:46:43Z Property ClientAosServer set to: ‘AX2012Local@SHIVATEJA-LT’
2012-08-08 18:46:43Z S270BCProxyAccountEntry
2012-08-08 18:46:49Z We do not recommend using your account B2BSOFTECH\shivateja for the Business Connector Proxy account. Contact your system administrator to create a dedicated account.
2012-08-08 18:46:49Z Property BusinessConnectorProxyAccount set to: ‘B2BSOFTECH\shivateja’
2012-08-08 18:46:53Z Property BusinessConnectorProxyAccountPassword set to: ‘**********’
2012-08-08 18:46:53Z S580ReportingServerInstance
2012-08-08 18:46:53Z 10.50.2500.0
2012-08-08 18:46:53Z MSSQLSERVER
2012-08-08 18:46:59Z Property ReportingServicesInstance set to: ‘MSSQLSERVER’
2012-08-08 18:46:59Z Property DeployReports set to: ‘1’
2012-08-08 18:46:59Z Loading prerequisites for component ‘’:
2012-08-08 18:46:59Z Computer restart pending
2012-08-08 18:46:59Z Microsoft .NET Framework 3.5 Service Pack 1
2012-08-08 18:46:59Z Domain user account
2012-08-08 18:46:59Z Local administrator
2012-08-08 18:46:59Z Microsoft Windows Installer
2012-08-08 18:46:59Z Adding prerequisite ‘Computer restart pending’.
2012-08-08 18:46:59Z Adding prerequisite ‘Microsoft .NET Framework 3.5 Service Pack 1’.
2012-08-08 18:46:59Z Adding prerequisite ‘Domain user account’.
2012-08-08 18:46:59Z Adding prerequisite ‘Local administrator’.
2012-08-08 18:46:59Z Adding prerequisite ‘Microsoft Windows Installer’.
2012-08-08 18:46:59Z Loading prerequisites for component ‘Reporting Services extensions’:
2012-08-08 18:46:59Z Server operating system
2012-08-08 18:46:59Z Application Object Server (AOS) Services WSDL URI accessible
2012-08-08 18:46:59Z Microsoft .NET Framework 4.0
2012-08-08 18:46:59Z Microsoft SQL Server Reporting Services
2012-08-08 18:47:00Z Required updates for Microsoft SQL Server
2012-08-08 18:47:00Z Microsoft SQL Server Reporting Services started
2012-08-08 18:47:00Z Microsoft SQL Server Reporting Services web service
2012-08-08 18:47:00Z Microsoft Visual C++ 2008 SP1 Redistributable (x86)
2012-08-08 18:47:00Z Microsoft Visual C++ 2008 SP1 Redistributable (x64)
2012-08-08 18:47:00Z Windows Identity Foundation
2012-08-08 18:47:00Z Adding prerequisite ‘Server operating system’.
2012-08-08 18:47:00Z Adding prerequisite ‘Application Object Server (AOS) Services WSDL URI accessible’.
2012-08-08 18:47:00Z Adding prerequisite ‘Microsoft .NET Framework 4.0’.
2012-08-08 18:47:00Z Adding prerequisite ‘Microsoft SQL Server Reporting Services’.
2012-08-08 18:47:00Z Adding prerequisite ‘Required updates for Microsoft SQL Server’.
2012-08-08 18:47:00Z Adding prerequisite ‘Microsoft SQL Server Reporting Services started’.
2012-08-08 18:47:00Z Adding prerequisite ‘Microsoft SQL Server Reporting Services web service’.
2012-08-08 18:47:00Z Adding prerequisite ‘Microsoft Visual C++ 2008 SP1 Redistributable (x86)’.
2012-08-08 18:47:00Z Adding prerequisite ‘Microsoft Visual C++ 2008 SP1 Redistributable (x64)’.
2012-08-08 18:47:00Z Adding prerequisite ‘Windows Identity Foundation’.
2012-08-08 18:47:00Z S630Prerequisites
2012-08-08 18:47:00Z H:\Ax 2012 Sw\ax2012
2012-08-08 18:47:00Z Components selected:
2012-08-08 18:47:00Z Reporting Services extensions
2012-08-08 18:47:00Z Loading prerequisites for component ‘’:
2012-08-08 18:47:00Z Computer restart pending
2012-08-08 18:47:00Z Microsoft .NET Framework 3.5 Service Pack 1
2012-08-08 18:47:00Z Domain user account
2012-08-08 18:47:00Z Local administrator
2012-08-08 18:47:00Z Microsoft Windows Installer
2012-08-08 18:47:00Z Adding prerequisite ‘Computer restart pending’.
2012-08-08 18:47:00Z Adding prerequisite ‘Microsoft .NET Framework 3.5 Service Pack 1’.
2012-08-08 18:47:00Z Adding prerequisite ‘Domain user account’.
2012-08-08 18:47:00Z Adding prerequisite ‘Local administrator’.
2012-08-08 18:47:00Z Adding prerequisite ‘Microsoft Windows Installer’.
2012-08-08 18:47:00Z Loading prerequisites for component ‘Reporting Services extensions’:
2012-08-08 18:47:00Z Server operating system
2012-08-08 18:47:00Z Application Object Server (AOS) Services WSDL URI accessible
2012-08-08 18:47:01Z Microsoft .NET Framework 4.0
2012-08-08 18:47:01Z Microsoft SQL Server Reporting Services
2012-08-08 18:47:01Z Required updates for Microsoft SQL Server
2012-08-08 18:47:01Z Microsoft SQL Server Reporting Services started
2012-08-08 18:47:01Z Microsoft SQL Server Reporting Services web service
2012-08-08 18:47:01Z Microsoft Visual C++ 2008 SP1 Redistributable (x86)
2012-08-08 18:47:01Z Microsoft Visual C++ 2008 SP1 Redistributable (x64)
2012-08-08 18:47:01Z Windows Identity Foundation
2012-08-08 18:47:01Z Adding prerequisite ‘Server operating system’.
2012-08-08 18:47:01Z Adding prerequisite ‘Application Object Server (AOS) Services WSDL URI accessible’.
2012-08-08 18:47:01Z Adding prerequisite ‘Microsoft .NET Framework 4.0’.
2012-08-08 18:47:01Z Adding prerequisite ‘Microsoft SQL Server Reporting Services’.
2012-08-08 18:47:01Z Adding prerequisite ‘Required updates for Microsoft SQL Server’.
2012-08-08 18:47:01Z Adding prerequisite ‘Microsoft SQL Server Reporting Services started’.
2012-08-08 18:47:01Z Adding prerequisite ‘Microsoft SQL Server Reporting Services web service’.
2012-08-08 18:47:01Z Adding prerequisite ‘Microsoft Visual C++ 2008 SP1 Redistributable (x86)’.
2012-08-08 18:47:01Z Adding prerequisite ‘Microsoft Visual C++ 2008 SP1 Redistributable (x64)’.
2012-08-08 18:47:01Z Adding prerequisite ‘Windows Identity Foundation’.
2012-08-08 18:47:01Z Checking the following prerequisites:
2012-08-08 18:47:01Z Performing a computer restart pending check for prerequisite ‘Computer restart pending’.
2012-08-08 18:47:01Z Check failed.
2012-08-08 18:47:01Z Resolution: Restart the computer before you install Microsoft Dynamics AX or its prerequisites.
2012-08-08 18:47:01Z For information about how the prerequisite was validated, click the View log file link. For detailed troubleshooting steps, see the troubleshooting section of the Installation Guide at http://go.microsoft.com/fwlink/?LinkId=211990.
2012-08-08 18:47:01Z Performing a registry value version check for prerequisite ‘Microsoft .NET Framework 3.5 Service Pack 1’.
2012-08-08 18:47:01Z Searching for a minimum version of ‘3.5.30729.1’.
2012-08-08 18:47:01Z Version found: ‘3.5.30729.5420’.
2012-08-08 18:47:01Z Check succeeded.
2012-08-08 18:47:01Z Performing a domain account check for prerequisite ‘Domain user account’.
2012-08-08 18:47:01Z Performing a local administrator check for prerequisite ‘Local administrator’.
2012-08-08 18:47:01Z Performing a windows installer version check for prerequisite ‘Microsoft Windows Installer’.
2012-08-08 18:47:01Z Searching for a minimum version of ‘3.0.0.0’.
2012-08-08 18:47:01Z Version found: ‘5.0.7601.17807’.
2012-08-08 18:47:01Z Performing an OS version check for prerequisite ‘Server operating system’.
2012-08-08 18:47:01Z Searching for a minimum version of ‘6.0.1.0’ and a suggested version of ‘6.0.1.0’.
2012-08-08 18:47:01Z Version found: ‘6.1.7601.0’.
2012-08-08 18:47:01Z Success
2012-08-08 18:47:01Z Performing a service status check for prerequisite ‘Application Object Server (AOS) Services WSDL URI accessible’.
2012-08-08 18:47:04Z Check succeeded.
2012-08-08 18:47:04Z Performing a .NET version check for prerequisite ‘Microsoft .NET Framework 4.0’.
2012-08-08 18:47:04Z Searching for a minimum version of ‘4.0.30319.0’.
2012-08-08 18:47:04Z Version found: ‘4.0.30319.0’.
2012-08-08 18:47:04Z Checking for the existence of the registry key ‘HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft.NetFramework\v4.0.30319\SKUs.NETFramework,Version=v4.0’.
2012-08-08 18:47:04Z Success
2012-08-08 18:47:04Z Performing a Microsoft SQLServer Reporting Services existence check for prerequisite ‘Microsoft SQL Server Reporting Services’.
2012-08-08 18:47:04Z 10.50.2500.0
2012-08-08 18:47:04Z MSSQLSERVER
2012-08-08 18:47:04Z Checking for the SSRS instance ‘MSSQLSERVER’.
2012-08-08 18:47:04Z SSRS Instance: MSSQLSERVER
2012-08-08 18:47:04Z Performing a Microsoft SQLServer CU3 check for prerequisite ‘Required updates for Microsoft SQL Server’.
2012-08-08 18:47:04Z Performing a Microsoft SQLServer Reporting Services status check for prerequisite ‘Microsoft SQL Server Reporting Services started’.
2012-08-08 18:47:04Z Checking the status of the service ‘MSSQLSERVER’.
2012-08-08 18:47:04Z Performing a Microsoft SQLServer Reporting Services URL check for prerequisite ‘Microsoft SQL Server Reporting Services web service’.
2012-08-08 18:47:04Z Looking for website ‘http://shivateja-lt/ReportServer’.
2012-08-08 18:47:04Z Performing an MSI package check for prerequisite ‘Microsoft Visual C++ 2008 SP1 Redistributable (x86)’.
2012-08-08 18:47:04Z Checking for installed MSI’s with an upgrade code ‘{AA783A14-A7A3-3D33-95F0-9A351D530011}’.
2012-08-08 18:47:04Z Searching for a minimum version of ‘9.0.30729.0’.
2012-08-08 18:47:04Z Version found: ‘9.0.30729.0’.
2012-08-08 18:47:04Z Performing an MSI package check for prerequisite ‘Microsoft Visual C++ 2008 SP1 Redistributable (x64)’.
2012-08-08 18:47:04Z Adding prerequisite ‘Computer restart pending’.
2012-08-08 18:47:04Z Adding prerequisite ‘Microsoft .NET Framework 3.5 Service Pack 1’.
2012-08-08 18:47:04Z Adding prerequisite ‘Domain user account’.
2012-08-08 18:47:04Z Adding prerequisite ‘Local administrator’.
2012-08-08 18:47:04Z Adding prerequisite ‘Microsoft Windows Installer’.
2012-08-08 18:
Hi, it would be good to know what exactly is interrupting your installation of Reporting Services.
A quick Google search already points out several useful articles about possible issues that one might have installing RS on a WIN7 machine:
http://blogical.se/blogs/jahlen/archive/2009/10/02/setting-up-sql-server-reporting-services-on-windows-7-vista-or-windows-2008.aspx
http://beyondrelational.com/modules/2/blogs/57/posts/11182/reporting-services-and-windows-7-home-premium.aspx
