Reporting Services in Ax2012
I have small doubt. My data base is SQL Server Express with SP1.can i install reporting services in that?
ya u can…
Hi Srikanth,
I tried my laptop (windows 7).In Ax 2012 Reporting services URL in added .but reports not deployed.at the time of deploying installation fails
can u tell me what is the error u r facing
This is error log open installation completion
=== Setup logging started: 8/8/2012 6:25:15 PM ===
Running file: “C:\Program Files\Microsoft Dynamics AX\60\SetupSupport\AxSetup.exe” RelatedFilesDir=“H:\Ax 2012 Sw\ax2012” AutoRun=1 LogDir=“C:\Program Files\Microsoft Dynamics AX\60\Setup Logs\2012-08-08 18-25-14”
AxSetup version number: 6.0.947.0
Microsoft Windows NT 6.1.7601 Service Pack 1 (64 bit)
SHIVATEJA-LT
B2BSOFTECH\shivateja
Interactive: True
2012-08-08 18:25:15Z RelatedFilesDir=H:\Ax 2012 Sw\ax2012
2012-08-08 18:25:15Z LogDir=C:\Program Files\Microsoft Dynamics AX\60\Setup Logs\2012-08-08 18-25-14
2012-08-08 18:25:15Z Property RelatedFilesDir set to: ‘H:\Ax 2012 Sw\ax2012’
2012-08-08 18:25:15Z Property LogDir set to: ‘C:\Program Files\Microsoft Dynamics AX\60\Setup Logs\2012-08-08 18-25-14’
2012-08-08 18:25:15Z Common Property Install Path set to ‘C:\Program Files\Microsoft Dynamics AX\60’.
2012-08-08 18:25:15Z Installation Path retrieved from registry. Value: ‘C:\Program Files\Microsoft Dynamics AX\60’
2012-08-08 18:25:15Z Initializing log file: C:\Program Files\Microsoft Dynamics AX\60\Setup Logs\2012-08-08 18-25-14\DynamicsSetupLog.txt
2012-08-08 18:25:15Z === Starting evaluation of existing installation state ===
2012-08-08 18:25:15Z Application Object Server instance 01 has been installed with the name 01-AX2012Local.
2012-08-08 18:25:15Z MSI file: Components64.msi Installed: True
2012-08-08 18:25:15Z MSI file: HelpServer64.msi Installed: False
2012-08-08 18:25:15Z MSI file: ClientOba64.msi Installed: True
2012-08-08 18:25:15Z MSI file: TraceParser.msi Installed: True
2012-08-08 18:25:15Z Previously Installed Component: Application Object Server (AOS) (01-AX2012Local)
2012-08-08 18:25:15Z Previously Installed Component: Management utilities
2012-08-08 18:25:15Z Previously Installed Component: .NET Business Connector
2012-08-08 18:25:15Z Previously Installed Component: Debugger
2012-08-08 18:25:15Z Previously Installed Component: Visual Studio Tools
2012-08-08 18:25:15Z Property RunMode set to: ‘AddRemoveFeatures’
2012-08-08 18:25:15Z === Starting UI phase ===
2012-08-08 18:25:15Z S030WelcomeInfo
2012-08-08 18:25:17Z S040MaintenanceMode
2012-08-08 18:25:21Z Property RemoveComponents set to: ‘0’
2012-08-08 18:25:21Z S080FeatureOption
2012-08-08 18:25:22Z Property BypassWarnings set to: ‘0’
2012-08-08 18:25:27Z Property InstallDatabase set to: ‘1’
2012-08-08 18:25:29Z Property InstallReportingServicesExtensions set to: ‘1’
2012-08-08 18:25:34Z Property ClientLanguage set to: ‘EN-US’
2012-08-08 18:25:34Z Property AosPort set to: ‘2712’
2012-08-08 18:25:34Z Property ClientAosServer set to: ‘SHIVATEJA-LT’
2012-08-08 18:25:35Z S640InitialPrerequisites
2012-08-08 18:25:35Z Loading data table ‘Microsoft.Dynamics.Setup.PrereqAssembly.PRRESXMAP.xml’.
2012-08-08 18:25:35Z Loading data table ‘Microsoft.Dynamics.Setup.PrereqAssembly.PRPRCMAP.xml’.
2012-08-08 18:25:35Z Loading data table ‘Microsoft.Dynamics.Setup.PrereqAssembly.PRCAMAP.xml’.
2012-08-08 18:25:35Z Loading data table ‘Microsoft.Dynamics.Setup.PrereqAssembly.COMPPRMAP.xml’.
2012-08-08 18:25:35Z Loading data table ‘Microsoft.Dynamics.Setup.PrereqAssembly.COMPDATA.xml’.
2012-08-08 18:25:35Z Loading prerequisites for component ‘’:
2012-08-08 18:25:35Z Computer restart pending
2012-08-08 18:25:35Z Microsoft .NET Framework 3.5 Service Pack 1
2012-08-08 18:25:35Z Domain user account
2012-08-08 18:25:35Z Local administrator
2012-08-08 18:25:35Z Microsoft Windows Installer
2012-08-08 18:25:35Z Adding prerequisite ‘Computer restart pending’.
2012-08-08 18:25:35Z Adding prerequisite ‘Microsoft .NET Framework 3.5 Service Pack 1’.
2012-08-08 18:25:35Z Adding prerequisite ‘Domain user account’.
2012-08-08 18:25:35Z Adding prerequisite ‘Local administrator’.
2012-08-08 18:25:35Z Adding prerequisite ‘Microsoft Windows Installer’.
2012-08-08 18:25:35Z Loading prerequisites for component ‘Databases’:
2012-08-08 18:25:35Z Loading prerequisites for component ‘Reporting Services extensions’:
2012-08-08 18:25:35Z Server operating system
2012-08-08 18:25:35Z Microsoft .NET Framework 4.0
2012-08-08 18:25:35Z Microsoft SQL Server Reporting Services
2012-08-08 18:25:35Z Required updates for Microsoft SQL Server
2012-08-08 18:25:35Z Microsoft SQL Server Reporting Services started
2012-08-08 18:25:35Z Microsoft SQL Server Reporting Services web service
2012-08-08 18:25:35Z Microsoft Visual C++ 2008 SP1 Redistributable (x86)
2012-08-08 18:25:35Z Microsoft Visual C++ 2008 SP1 Redistributable (x64)
2012-08-08 18:25:35Z Windows Identity Foundation
2012-08-08 18:25:35Z Adding prerequisite ‘Server operating system’.
2012-08-08 18:25:35Z Adding prerequisite ‘Microsoft .NET Framework 4.0’.
2012-08-08 18:25:35Z Adding prerequisite ‘Microsoft SQL Server Reporting Services’.
2012-08-08 18:25:35Z Adding prerequisite ‘Required updates for Microsoft SQL Server’.
2012-08-08 18:25:35Z Adding prerequisite ‘Microsoft SQL Server Reporting Services started’.
2012-08-08 18:25:35Z Adding prerequisite ‘Microsoft SQL Server Reporting Services web service’.
2012-08-08 18:25:35Z Adding prerequisite ‘Microsoft Visual C++ 2008 SP1 Redistributable (x86)’.
2012-08-08 18:25:35Z Adding prerequisite ‘Microsoft Visual C++ 2008 SP1 Redistributable (x64)’.
2012-08-08 18:25:35Z Adding prerequisite ‘Windows Identity Foundation’.
2012-08-08 18:25:35Z H:\Ax 2012 Sw\ax2012
2012-08-08 18:25:35Z Components selected:
2012-08-08 18:25:35Z Databases
2012-08-08 18:25:35Z Reporting Services extensions
2012-08-08 18:25:36Z Domain user account
2012-08-08 18:25:36Z Local administrator
2012-08-08 18:25:36Z Microsoft Windows Installer
2012-08-08 18:25:36Z Adding prerequisite ‘Computer restart pending’.
2012-08-08 18:25:36Z Adding prerequisite ‘Microsoft .NET Framework 3.5 Service Pack 1’.
2012-08-08 18:25:36Z Adding prerequisite ‘Domain user account’.
2012-08-08 18:25:36Z Adding prerequisite ‘Local administrator’.
2012-08-08 18:25:36Z Adding prerequisite ‘Microsoft Windows Installer’.
2012-08-08 18:25:36Z Loading prerequisites for component ‘Databases’:
2012-08-08 18:25:36Z Computer restart pending
2012-08-08 18:25:36Z Microsoft .NET Framework 3.5 Service Pack 1
2012-08-08 18:25:36Z Loading prerequisites for component ‘Reporting Services extensions’:
2012-08-08 18:25:36Z Server operating system
2012-08-08 18:25:36Z Microsoft .NET Framework 4.0
2012-08-08 18:25:36Z Microsoft SQL Server Reporting Services
2012-08-08 18:25:36Z Required updates for Microsoft SQL Server
2012-08-08 18:25:36Z Microsoft SQL Server Reporting Services started
2012-08-08 18:25:36Z Microsoft SQL Server Reporting Services web service
2012-08-08 18:25:36Z Microsoft Visual C++ 2008 SP1 Redistributable (x86)
2012-08-08 18:25:36Z Microsoft Visual C++ 2008 SP1 Redistributable (x64)
2012-08-08 18:25:36Z Windows Identity Foundation
2012-08-08 18:25:36Z Adding prerequisite ‘Server operating system’.
2012-08-08 18:25:36Z Adding prerequisite ‘Microsoft .NET Framework 4.0’.
2012-08-08 18:25:36Z Adding prerequisite ‘Microsoft SQL Server Reporting Services’.
2012-08-08 18:25:36Z Adding prerequisite ‘Required updates for Microsoft SQL Server’.
2012-08-08 18:25:36Z Adding prerequisite ‘Microsoft SQL Server Reporting Services started’.
2012-08-08 18:25:36Z Adding prerequisite ‘Microsoft SQL Server Reporting Services web service’.
2012-08-08 18:25:36Z Adding prerequisite ‘Microsoft Visual C++ 2008 SP1 Redistributable (x86)’.
2012-08-08 18:25:36Z Adding prerequisite ‘Microsoft Visual C++ 2008 SP1 Redistributable (x64)’.
2012-08-08 18:25:36Z Adding prerequisite ‘Windows Identity Foundation’.
2012-08-08 18:25:36Z Checking the following prerequisites:
2012-08-08 18:25:36Z Performing a computer restart pending check for prerequisite ‘Computer restart pending’.
2012-08-08 18:25:36Z Check succeeded.
2012-08-08 18:25:36Z Performing a registry value version check for prerequisite ‘Microsoft .NET Framework 3.5 Service Pack 1’.
2012-08-08 18:25:36Z Searching for a minimum version of ‘3.5.30729.1’.
2012-08-08 18:25:36Z Version found: ‘3.5.30729.5420’.
2012-08-08 18:25:36Z Performing a domain account check for prerequisite ‘Domain user account’.
2012-08-08 18:25:36Z Performing a local administrator check for prerequisite ‘Local administrator’.
2012-08-08 18:25:36Z Performing a windows installer version check for prerequisite ‘Microsoft Windows Installer’.
2012-08-08 18:25:36Z Searching for a minimum version of ‘3.0.0.0’.
2012-08-08 18:25:36Z Version found: ‘5.0.7601.17807’.
2012-08-08 18:25:36Z Performing an OS version check for prerequisite ‘Server operating system’.
2012-08-08 18:25:37Z Searching for a minimum version of ‘6.0.1.0’ and a suggested version of ‘6.0.1.0’.
2012-08-08 18:25:37Z Version found: ‘6.1.7601.0’.
2012-08-08 18:25:37Z Check succeeded.
2012-08-08 18:25:37Z Success
2012-08-08 18:25:37Z Performing a .NET version check for prerequisite ‘Microsoft .NET Framework 4.0’.
2012-08-08 18:25:37Z Searching for a minimum version of ‘4.0.30319.0’.
2012-08-08 18:25:37Z Version found: ‘4.0.30319.0’.
2012-08-08 18:25:37Z Checking for the existence of the registry key ‘HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft.NetFramework\v4.0.30319\SKUs.NETFramework,Version=v4.0’.
2012-08-08 18:25:37Z Performing a Microsoft SQLServer Reporting Services existence check for prerequisite ‘Microsoft SQL Server Reporting Services’.
2012-08-08 18:25:37Z 10.50.2500.0
2012-08-08 18:25:37Z MSSQLSERVER
2012-08-08 18:25:37Z Performing a Microsoft SQLServer CU3 check for prerequisite ‘Required updates for Microsoft SQL Server’.
2012-08-08 18:25:37Z Performing a Microsoft SQLServer Reporting Services status check for prerequisite ‘Microsoft SQL Server Reporting Services started’.
2012-08-08 18:25:37Z Performing a Microsoft SQLServer Reporting Services URL check for prerequisite ‘Microsoft SQL Server Reporting Services web service’.
2012-08-08 18:25:37Z Looking for website ‘http://shivateja-lt/ReportServer’.
2012-08-08 18:26:05Z Check succeeded.
2012-08-08 18:26:05Z Performing an MSI package check for prerequisite ‘Microsoft Visual C++ 2008 SP1 Redistributable (x86)’.
2012-08-08 18:26:05Z Checking for installed MSI’s with an upgrade code ‘{AA783A14-A7A3-3D33-95F0-9A351D530011}’.
2012-08-08 18:26:05Z Searching for a minimum version of ‘9.0.30729.0’.
2012-08-08 18:26:05Z Version found: ‘9.0.30729.0’.
2012-08-08 18:26:05Z Success
2012-08-08 18:26:05Z Performing an MSI package check for prerequisite ‘Microsoft Visual C++ 2008 SP1 Redistributable (x64)’.
2012-08-08 18:26:10Z S161InstallModelDatabaseTypeOption
2012-08-08 18:26:15Z Property InstallDatabase set to: ‘2’
2012-08-08 18:26:15Z S163ModelSqlDatabaseNameSelection
2012-08-08 18:26:15Z Property DbSqlServer set to: ‘SHIVATEJA-LT’
2012-08-08 18:26:25Z Property DbSqlDatabaseName set to: ‘AX2012Local’
2012-08-08 18:26:25Z Property DbSqlModelStoreBaseline set to: ‘AX2012LocalBaseline’
2012-08-08 18:26:25Z Property UpgradeDB set to: ‘0’
2012-08-08 18:26:25Z S620ModelSelection
2012-08-08 18:26:52Z Model Process Manufacturing (Microsoft Corporation) not found.
2012-08-08 18:26:52Z Model Process Manufacturing Upgrade (Microsoft Corporation) not found.
2012-08-08 18:26:52Z Model Public Sector (Microsoft Corporation) not found.
2012-08-08 18:26:52Z Model Project Management Upgrade (Microsoft Corporation) not found.
2012-08-08 18:26:53Z Model Project Management Upgrade (Microsoft Corporation) not found.
2012-08-08 18:26:53Z Model Process Manufacturing (Microsoft Corporation) not found.
2012-08-08 18:26:53Z Model Process Manufacturing Upgrade (Microsoft Corporation) not found.
2012-08-08 18:26:53Z Model Public Sector (Microsoft Corporation) not found.
2012-08-08 18:26:54Z Model Project Management Upgrade (Microsoft Corporation) not found.
2012-08-08 18:26:54Z Model Process Manufacturing (Microsoft Corporation) not found.
2012-08-08 18:26:54Z Model Process Manufacturing Upgrade (Microsoft Corporation) not found.
2012-08-08 18:26:54Z Model Public Sector (Microsoft Corporation) not found.
2012-08-08 18:26:54Z OPTIONAL model H:\Ax 2012 Sw\ax2012\Models\ProcessIndustries\ProcessManufacturing.axmodel is found.
2012-08-08 18:26:54Z OPTIONAL model H:\Ax 2012 Sw\ax2012\Models\ProcessIndustries\ProcessManufacturingUpgrade.axmodel is found.
2012-08-08 18:26:54Z OPTIONAL model H:\Ax 2012 Sw\ax2012\Models\PublicSector\PublicSector.axmodel is found.
2012-08-08 18:26:54Z OPTIONAL model H:\Ax 2012 Sw\ax2012\Models\ServiceIndustries\ProjectFeaturePackUpgrade.axmodel is found.
2012-08-08 18:26:54Z MANDATORY model H:\Ax 2012 Sw\ax2012\Models\Standard\ProcessManufacturing.axmodel is found.
2012-08-08 18:26:54Z MANDATORY model H:\Ax 2012 Sw\ax2012\Models\Standard\ProcessManufacturingUpgrade.axmodel is found.
2012-08-08 18:26:54Z Already installed OPTIONAL model H:\Ax 2012 Sw\ax2012\Models\Labels\FoundationLabels.axmodel is found.
2012-08-08 18:26:54Z Already installed OPTIONAL model H:\Ax 2012 Sw\ax2012\Models\ServiceIndustries\ProjectFeaturePack.axmodel is found.
2012-08-08 18:26:54Z Already installed MANDATORY model H:\Ax 2012 Sw\ax2012\Models\Standard\Foundation.axmodel is found.
2012-08-08 18:26:54Z Already installed OPTIONAL model H:\Ax 2012 Sw\ax2012\Models\Upgrade\FoundationUpgrade.axmodel is found.
2012-08-08 18:26:57Z Property AosPort set to: ‘2712’
2012-08-08 18:26:57Z Property AosWsdlPort set to: ‘8101’
2012-08-08 18:26:57Z Property ClientAosServer set to: ‘AX2012Local@SHIVATEJA-LT’
2012-08-08 18:26:57Z S270BCProxyAccountEntry
2012-08-08 18:27:08Z We do not recommend using your account B2BSOFTECH\shivateja for the Business Connector Proxy account. Contact your system administrator to create a dedicated account.
2012-08-08 18:27:08Z Property BusinessConnectorProxyAccount set to: ‘B2BSOFTECH\shivateja’
2012-08-08 18:27:08Z Property BusinessConnectorProxyAccountPassword set to: ‘**********’
2012-08-08 18:27:08Z S580ReportingServerInstance
2012-08-08 18:27:08Z 10.50.2500.0
2012-08-08 18:27:08Z MSSQLSERVER
2012-08-08 18:27:11Z Property ReportingServicesInstance set to: ‘MSSQLSERVER’
2012-08-08 18:27:11Z Property DeployReports set to: ‘1’
2012-08-08 18:27:11Z Loading prerequisites for component ‘’:
2012-08-08 18:27:11Z Computer restart pending
2012-08-08 18:27:11Z Microsoft .NET Framework 3.5 Service Pack 1
2012-08-08 18:27:11Z Domain user account
2012-08-08 18:27:11Z Local administrator
2012-08-08 18:27:11Z Microsoft Windows Installer
2012-08-08 18:27:11Z Adding prerequisite ‘Computer restart pending’.
2012-08-08 18:27:11Z Adding prerequisite ‘Microsoft .NET Framework 3.5 Service Pack 1’.
2012-08-08 18:27:11Z Adding prerequisite ‘Domain user account’.
2012-08-08 18:27:11Z Adding prerequisite ‘Local administrator’.
2012-08-08 18:27:11Z Adding prerequisite ‘Microsoft Windows Installer’.
2012-08-08 18:27:11Z Loading prerequisites for component ‘Databases’:
2012-08-08 18:27:11Z Microsoft SQL Server Full-Text Search
2012-08-08 18:27:11Z SQL Server Full-text Filter Daemon Launcher service startup type
2012-08-08 18:27:11Z SQL Server Full-text Filter Daemon Launcher service started
2012-08-08 18:27:11Z Adding prerequisite ‘Microsoft SQL Server Full-Text Search’.
2012-08-08 18:27:11Z Adding prerequisite ‘SQL Server Full-text Filter Daemon Launcher service startup type’.
2012-08-08 18:27:11Z Adding prerequisite ‘SQL Server Full-text Filter Daemon Launcher service started’.
2012-08-08 18:27:11Z Adding prerequisite ‘Microsoft SQL Server (Databases)’.
2012-08-08 18:27:11Z Loading prerequisites for component ‘Reporting Services extensions’:
2012-08-08 18:27:11Z Server operating system
2012-08-08 18:27:12Z Application Object Server (AOS) Services WSDL URI accessible
2012-08-08 18:27:12Z Microsoft .NET Framework 4.0
2012-08-08 18:27:12Z Microsoft SQL Server Reporting Services
2012-08-08 18:27:12Z Required updates for Microsoft SQL Server
2012-08-08 18:27:12Z Microsoft SQL Server Reporting Services started
2012-08-08 18:27:12Z Microsoft SQL Server Reporting Services web service
2012-08-08 18:27:12Z Microsoft Visual C++ 2008 SP1 Redistributable (x86)
2012-08-08 18:27:12Z Microsoft Visual C++ 2008 SP1 Redistributable (x64)
2012-08-08 18:27:12Z Windows Identity Foundation
2012-08-08 18:27:12Z Adding prerequisite ‘Server operating system’.
2012-08-08 18:27:12Z Adding prerequisite ‘Application Object Server (AOS) Services WSDL URI accessible’.
2012-08-08 18:27:12Z Adding prerequisite ‘Microsoft .NET Framework 4.0’.
2012-08-08 18:27:12Z Adding prerequisite ‘Microsoft SQL Server Reporting Services’.
2012-08-08 18:27:12Z Adding prerequisite ‘Required updates for Microsoft SQL Server’.
2012-08-08 18:27:12Z Adding prerequisite ‘Microsoft SQL Server Reporting Services started’.
2012-08-08 18:27:12Z Adding prerequisite ‘Microsoft SQL Server Reporting Services web service’.
2012-08-08 18:27:12Z Adding prerequisite ‘Microsoft Visual C++ 2008 SP1 Redistributable (x86)’.
2012-08-08 18:27:12Z Adding prerequisite ‘Microsoft Visual C++ 2008 SP1 Redistributable (x64)’.
2012-08-08 18:27:12Z Adding prerequisite ‘Windows Identity Foundation’.
2012-08-08 18:27:12Z S630Prerequisites
2012-08-08 18:27:12Z H:\Ax 2012 Sw\ax2012
2012-08-08 18:27:12Z Components selected:
2012-08-08 18:27:12Z Databases
2012-08-08 18:27:12Z Reporting Services extensions
2012-08-08 18:27:12Z Loading prerequisites for component ‘’:
2012-08-08 18:27:12Z Computer restart pending
2012-08-08 18:27:12Z Microsoft .NET Framework 3.5 Service Pack 1
2012-08-08 18:27:12Z Domain user account
2012-08-08 18:27:12Z Local administrator
2012-08-08 18:27:12Z Microsoft Windows Installer
2012-08-08 18:27:12Z Adding prerequisite ‘Computer restart pending’.
2012-08-08 18:27:12Z Adding prerequisite ‘Microsoft .NET Framework 3.5 Service Pack 1’.
2012-08-08 18:27:12Z Adding prerequisite ‘Domain user account’.
2012-08-08 18:27:12Z Adding prerequisite ‘Local administrator’.
2012-08-08 18:27:12Z Adding prerequisite ‘Microsoft Windows Installer’.
2012-08-08 18:27:12Z Loading prerequisites for component ‘Databases’:
2012-08-08 18:27:13Z Microsoft .NET Framework 3.5 Service Pack 1
2012-08-08 18:27:13Z Microsoft SQL Server Full-Text Search
2012-08-08 18:27:13Z SQL Server Full-text Filter Daemon Launcher service startup type
2012-08-08 18:27:13Z SQL Server Full-text Filter Daemon Launcher service started
2012-08-08 18:27:13Z Adding prerequisite ‘Microsoft SQL Server Full-Text Search’.
2012-08-08 18:27:13Z Adding prerequisite ‘SQL Server Full-text Filter Daemon Launcher service startup type’.
2012-08-08 18:27:13Z Adding prerequisite ‘SQL Server Full-text Filter Daemon Launcher service started’.
2012-08-08 18:27:13Z Adding prerequisite ‘Microsoft SQL Server (Databases)’.
2012-08-08 18:27:13Z Loading prerequisites for component ‘Reporting Services extensions’:
2012-08-08 18:27:13Z Computer restart pending
2012-08-08 18:27:13Z Server operating system
2012-08-08 18:27:13Z Application Object Server (AOS) Services WSDL URI accessible
2012-08-08 18:27:13Z Microsoft .NET Framework 4.0
2012-08-08 18:27:13Z Microsoft SQL Server Reporting Services
2012-08-08 18:27:13Z Required updates for Microsoft SQL Server
2012-08-08 18:27:13Z &nb
Please find the error log attachment
0385.DynamicsSetupLog.txt (90 KB)
Hi Kishore,
As far as I know, AX SSRS reports wont work with Express edition of SQL.
Best Regards,
Michael
while installing ax 2012 pre-checker will be there ,check the all the compenents and try to install reporting service from there.
Hi Srikanth,
I checked all prerequisites.it shows no error.
Dear All,
Could you please confirm is it possible to deploy AX 2012 reports in SQL Express 2008?
Regards
Uday
