Reporting Extensions
Hi everyone,
While installing the “Reporting Extensions”, when I put check mark on “Reporting Extensions” the below error message was coming
“You must install SQL Server 2005 Reporting Services Service Pack 2 before installing the Reporting Extensions”
My System Configuration is:
àWindows Server 2003 OS
àAX 2009 SP1
àSQL Server 2008 R2 developer edition
àSQL Server 2005 Reporting Services with SP1, SP2 and SP3
And I even did copy the “Microsoft.Dynamics.Setup. ReportingServices.dll file” from AX 2009 SP1 and the same has been pasted in to the C:\Program Files\Microsoft Dynamics AX\50\Setup
But still I am getting the same error
Can anyone tell me the solution?
Try following the information in this link:
https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?WTNTZSMNWUKNTMMYXUPYZQPOUXNXSPSYRYYMQTUNYUROMKPUTXTUVNQONXVWPPQN
