I have one query regarding AX report.
I want make report control field invisible at run time. if the field don’t have value then it should not visible in report .
How to do it. Please help.
Nitish Kr
Nitish Kr
In your fetch method, u can do this… assign that value to a variable…then put a condition like if !(variable) { formfield.visible(false); } else { formfield.visible(true);}
Meanwhile, make the formfield - AutoDeclaration in the property to YES …\
thats it…
Thanks and Regards,
Kevin
If your report doesn’t have a fetch method, you can add an executeSection() method in your report section and test your field’s value, like this: if … yourField.visible(false)
Hope it helps
Thomas
hi,
If that field is numeric then you can set property “ShowZero” to No.
Thanks & Regards,
Mehul Thacker
