Report
I recently started working with Navision. I don’t have much knowledge about it, but i am trying to pick up though the manuals.
Could someone please tell me how to add the option tab to a report? I am writing a custom report which needs to print three times every time its run. I suppose i need the option tab? or if anyone has a better idea please let me know.
Design Report Select View → Request Form
Thank you for the prompt response. That works, Now i need the code in the trigger. This is what i have so far. Do i need to change anything or this should work?
CopyLoop - OnPreDataItem()
NoLoops := 1 + ABS(NoCopies);
IF NoLoops <= 0 THEN
NoLoops := 1;
CopyNo := 0;
CopyLoop - OnAfterGetRecord()
CurrReport.PAGENO := 1;
IF CopyNo = NoLoops THEN BEGIN
IF NOT CurrReport.PREVIEW THEN
SalesPrinted.RUN(“Sales Header”);
CurrReport.BREAK;
END ELSE
CopyNo := CopyNo + 1;
IF CopyNo = 1 THEN // Original
CLEAR(CopyTxt)
ELSE
CopyTxt := Text000;
That the code available in sales invoices and other reports, it should work.
Thank you very much.
I will test it and will let you know.
