In the midst of putting together a report in NAV (v4.0 SP3), something happened that prevents the report from being loaded into the Object Designer. I had just entered a lengthy text string into the SourceExpr of a textbox, compiled and tested the report, then went back to open it for more modification. Instead of seeing the Report Designer window, I’m presented with the message “Microsoft Business Solutions-Navision has encountered a problem and needs to close. We are sorry for the inconvenience.”, and a choice of whether or not I want to send an error report to MS, which I did. I’ve tried several times to open this report, all with the same result. The ‘broken’ report runs, albeit with only part of the text I entered, and other reports still open in the designer.
Is there some way to find out and repair what’s causing the Designer to choke?
GeofS
