In object designer when i access this report “Trial Balance Detail/Summary” the Nav freeze…any type of access: Design,Run,Compile…
what should I Do?
I want to modify it …
what should I Do?
What is database size ?
Is any maintenance activity done on database for performance improvement ?
Any changes/customization done in the report ?
Hi Oussama,
I have experienced something very similar in NAV 2009. Here I couldn’t even export the object, nor delete it. The only thing that worked was replacing the object with a backup from my development version.
Later I found out that the reason was that my local development system (where the report had been developed) had a more recent build than the version my customer was running. And until I got the customer upgraded to the same version as mine, then the only work-around was to only import the objects as text-files instead of the pre-compiled FOB files.
