I do have “Item No.” field in a temp table. But, I’d need to also show Item.Description on the report in the Integer area.
There is no any available field with a needed length in the temp table I could use for it.
I was trying:
IF Item.GET(tblTemp.“Item No.”) THEN
Item_Description:=Item.Description
It’s working good I could get a correct value in the code but how to show it on the report? I did also try to use Item_Description[i] as an array lopping through it in the AfterGetRecord()but no success for now.
I do have several nested temp tables that seems as working well as Integers in DataItem and on the Report.
On a one of the integer in the DataItem I was trying to use this GET , in OnPreDataItem when I was doing REPEAT … UNTIL for the Temp table and I also tried the GET in AfterGetRecord for the same Integer when I’m doing
OnAfterGetRecord()
IF Number = 1 THEN
tmpTable.FIND('-')
ELSE
tmpTable.NEXT;.
On the report I’d need to show it in the Integer section where I show other relevant data such as “Item No,” there, So, I’d need to show the Item.Description there too.
Ok, I tried the code below but it shows the last value only for all Items when I put Item_Description on the TempIntTSE section of the report. So, I have a list of different Items there but the Description is the same for all Items that is actually the last value of the variable Item_Description.
