Respected All,
I have a customized classic report that I linked with RTC, The report is running fine in Classic Client, but when i the run report in RTC the running Service restarted !
Please mail to : mrinal@samadhanindia.com [if you need the Report fob]
Here is the Event log about the Error :
System
Provider
[ Name] MicrosoftDynamicsNAVClient
- EventID 0
[ Qualifiers] 0
Level 2
Task 0
Keywords 0x80000000000000
- TimeCreated
[ SystemTime] 2011-12-09T11:01:05.000Z
EventRecordID 95316
Channel Application
Computer server1.*.com
Security
- EventData
Type: Microsoft.Dynamics.Nav.Client.NavClientClosingException
Message: The connection to the server has been lost. The application will close.
StackTrace: at Microsoft.Dynamics.Nav.Client.ExceptionHandler.DoExecute(Func`1 execute) at Microsoft.Dynamics.Nav.Client.ExceptionHandler.DoRethrowWithCatchException(Exception exception) at
Microsoft.Dynamics.Nav.Client.ExceptionHandler.Application_ThreadException(Object sender, ThreadExceptionEventArgs e)
at System.Windows.Forms.Application.ThreadContext.OnThreadException(Exception t)
at System.Windows.Forms.Control.WndProcException(Exception e)
at System.Windows.Forms.Control.ControlNativeWindow.OnThreadException(Exception e)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
at System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg)
at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(Int32 dwComponentID, Int32 reason, Int32 pvLoopData)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)
at System.Windows.Forms.Application.Run(ApplicationContext context)
at Microsoft.Dynamics.Nav.Client.WinClient.RunCore()
at Microsoft.Dynamics.Nav.Client.ExceptionHandler.ExecuteAndCatchExceptions(Func`1 execute)
at Microsoft.Dynamics.Nav.Client.WinClient.Run()
Source: Microsoft.Dynamics.Nav.Client ----------------------------------
Type: Microsoft.Dynamics.Nav.Types.NavConnectionLostException
StackTrace: at Microsoft.Dynamics.Nav.Client.ExceptionHandler.<>c__DisplayClass2.b__0()
Type: Microsoft.Dynamics.Nav.Types.NavConnectionLostException Message: The connection to the server has been lost. The application will close. StackTrace: at Microsoft.Dynamics.Nav.Client.ConnectionStateManager.HandleCommunicationFailure[T](CallServerMethod1 callServerMethod, Exception e, Int32 messageNumber, String sessionId) at Microsoft.Dynamics.Nav.Client.ConnectionStateManager.CallServer[T](CallServerMethod
1 callServerMethod) at Microsoft.Dynamics.Nav.Client.ServerInvocationHandler.CallServer[T](CallServerMethod1 callServerMethod) at Microsoft.Dynamics.Nav.Client.ServiceConnectionBase.CallServer[T](CallServerMethod
1 callServerMethod) at Microsoft.Dynamics.Nav.Client.ServiceConnection.ActionField(NavRecordState& state, NavDataSet recDataSet, String controlTriggerMethodName) at Microsoft.Dynamics.Nav.Client.DataBinder.NstDataAccess.ActionMethod(String triggerName) at Microsoft.Dynamics.Nav.Client.Actions.InvokePageTriggerAction.InvokeTrigger(LogicalControl logicalControl, UISession uiSession) at Microsoft.Dynamics.Nav.Client.Actions.InvokePageTriggerAction.InvokeCore(Boolean async, LogicalControl logicalControl, Object state, UISession uiSession) at Microsoft.Dynamics.Framework.UI.Action.InvokeCoreWithErrorHandling(Boolean async, LogicalControl logicalControl, Object state, UISession uiSession) at Microsoft.Dynamics.Framework.UI.Action.DoInvoke(LogicalControl logicalControl, UISession uiSession) at Microsoft.Dynamics.Framework.UI.ActionControl.Invoke() at Microsoft.Dynamics.Framework.UI.Windows.ActionControlAdapterBase.DefaultInvokeAction(LogicalControlAdapter adapter, ActionControl actionControl) at Microsoft.Dynamics.Framework.UI.Windows.ActionControlAdapterBase.DefaultInvokeAction(LogicalControlAdapter adapter) at Microsoft.Dynamics.Framework.UI.Windows.ActionControlAdapterBase.OnInvoke() at Microsoft.Dynamics.Framework.UI.WinForms.MenuBarActionControlAdapter.b__0(Object sender, EventArgs e) at System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e) at System.Windows.Forms.ToolStripMenuItem.OnClick(EventArgs e) at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e) at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e) at System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e, ToolStripItemEventType met) at System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e, ToolStripItemEventType met) at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea) at System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea) at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ScrollableControl.WndProc(Message& m) at System.Windows.Forms.ToolStrip.WndProc(Message& m) at System.Windows.Forms.ToolStripDropDown.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) Source: Microsoft.Dynamics.Nav.Client.ServiceConnection ---------------------------------- Type: System.ServiceModel.FaultException Action: schemas.microsoft.com/…/fault
Message: The server was unable to process the request due to an internal error. For more information about the error, either turn on IncludeExceptionDetailInFaults (either from ServiceBehaviorAttribute or from the configuration behavior) on the server in order to send the exception information back to the client, or turn on tracing as per the Microsoft .NET Framework 3.0 SDK documentation and inspect the server trace logs. StackTrace: Server stack trace: at System.ServiceModel.Channels.ServiceChannel.ThrowIfFaultUnderstood(Message reply, MessageFault fault, String action, MessageVersion version, FaultConverter faultConverter) at System.ServiceModel.Channels.ServiceChannel.HandleReply(ProxyOperationRuntime operation, ProxyRpc& rpc) at System.ServiceModel.Channels.ServiceChannel.Call(String action, Boolean oneway, ProxyOperationRuntime operation, Object[] ins, Object[] outs, TimeSpan timeout) at System.ServiceModel.Channels.ServiceChannel.Call(String action, Boolean oneway, ProxyOperationRuntime operation, Object[] ins, Object[] outs) at System.ServiceModel.Channels.ServiceChannelProxy.InvokeService(IMethodCallMessage methodCall, ProxyOperationRuntime operation) at System.ServiceModel.Channels.ServiceChannelProxy.Invoke(IMessage message) Exception rethrown at [0]: at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type) at Microsoft.Dynamics.Nav.Types.INavService.ActionField(FieldRequest fieldRequest, NavRecordState dataSetState) at Microsoft.Dynamics.Nav.Client.ServiceConnection.<>c__DisplayClass47.b__46() at Microsoft.Dynamics.Nav.Client.ServerCallContext1.InvokeCall(Object instance) at System.Runtime.Remoting.Messaging.StackBuilderSink._PrivateProcessMessage(IntPtr md, Object[] args, Object server, Int32 methodPtr, Boolean fExecuteInContext, Object[]& outArgs) at System.Runtime.Remoting.Messaging.StackBuilderSink.PrivateProcessMessage(RuntimeMethodHandle md, Object[] args, Object server, Int32 methodPtr, Boolean fExecuteInContext, Object[]& outArgs) at System.Runtime.Remoting.Messaging.StackBuilderSink.AsyncProcessMessage(IMessage msg, IMessageSink replySink) Exception rethrown at [1]: at System.Runtime.Remoting.Proxies.RealProxy.EndInvokeHelper(Message reqMsg, Boolean bProxyCase) at System.Runtime.Remoting.Proxies.RemotingProxy.Invoke(Object NotUsed, MessageData& msgData) at System.Threading.WaitCallback.EndInvoke(IAsyncResult result) at Microsoft.Dynamics.Nav.Client.ServerInvocationManager.CallServer[T](CallServerMethod
1 callServerMethod) at Microsoft.Dynamics.Nav.Client.ServerInvocationHandler.CallServer[T](CallServerMethod1 callServerMethod) at Microsoft.Dynamics.Nav.Client.ConnectionStateManager.CallServer[T](CallServerMethod
1 callServerMethod) Source: mscorlib
